Washing Machines Logo
Kevin Reid Posted on Jan 17, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Having trouble getting the edit buttons on the drum machine to work
Attique-ur-Rehman
Level 3:
Top Expert:
  • Washing Mach... Master 2,677 Answers
  • Posted on Apr 19, 2020
Attique-ur-Rehman
Level 3:
Top Expert:
Answers
2677
Questions
Helped
878873
Points
8006
The drum will not go round
Ask yourself these questions (forgive me if they start of simple) Have you used the machine before - this will determine if you are pressing the correct buttons to initiate the drum to go around. Is the machine getting power? Are other elements of the machine working like flashing light etc? This may help you to deduct if the problem is electrical, mechanical, operational, etc. Try spinning drum with machine off. Common problem is that belt has broken or come of. You could view this by taken cover of the back and having a visual inspection. ONLY DO THIS WITH POWER OFF. Some models have a trip switch which will turn off if belt breaks - this is because if machine stays on while drum isn't spinning, it would be like putting your cloths in the oven. Good luck and let us know how u go
p.s Don't forget the button on the door
Aug 08, 2011 • Dryers
Its having a drum error. please help now
First did you follow instructions of reseting machine , if not here is the istructions, with machine in ready state, press go button and up arrow at same time, the reset parts life comes up, use up arrow or down arrow to scroll thru to drum replacement, press the ok button when you get to drum, the machine will have drum unit ok?, press okay, machine will cycle and reset drum.
  1. When you replace the drum unit with a new one, or just want to extend the life of your existing drum unit, you need to reset the drum counter by completing the following steps:
  2. Press the + or - button to choose "Machine Info".
  3. Press OK to proceed to the next menu level, and then press the + or - button to choose
    "Reset Parts Life".
  4. Press OK, and then press the + button to choose "Drum Unit".
  5. Press OK two times.
  6. --------------------- This should help.Thanks.Helpmech.
WATER IS NOT DRAINING. CHECKED HOSE, PUMP, BELT, ETC. WANT TO SEE IF PLUGGED WITH CLOTHES AROUND DRUM BUT AM HAVING TROUBLE GETTING LID OFF. PUSHED IN LOCKS WITH PUTTY KNIFE AND STILL LID WILL NOT LIFT.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
I have a Ricoh 2232c copier. The ink is fading. I changed a drum and cleaned the machine. I was having troubles with the waste toner lines being clogged but I cleaned the lines and it seems to be...
drums and dev units are meant to last 80 k so check the age.2 have u cleaned the optics? very very important.3 do auto colour calibration in system menu 123 button.or u should be doing it at least 1ce a week.oil has nothing to do with it.
Screw jammed in between inner and outer drum
I take it you have the drum removed from the machine completeley, the only thing holding them together should be a rubber gasket, Have you taken the weight from the front and removed all the screws behind the weight?
could you not move the screw to the bottom of the tub, remove the heater and then remove the screw, stripping down the whole machine is a lot of work, at least an hour and a half and a sore back into the bargin.
I am having trouble replacing my washing machine belt.
Make sure that yo have the correct belt. I am sure that you have already done this. It sound like the drum it stuck. Make sure the drum will spin. Also without the the belt on make sure the motor will work on its known. See if this will help
10helpful
5answers
Ps2 guitar hero world tour
clean the lens on your system and then start up ps2 with no disc. highlight browser and hit green triangle. highlight console and hit triangle. highlight diagnostics hit blue x button and select on. press red o button to back up. highlight playstation drive and hit green triangle. highlight disc speed and hit blue x button and select fast. press red o button to back out. turn off machine, insert guitar hero 2 and turn machine on. This solution worked for me and we have been having fun ever since. Good luck and may God be with you.
Wireless remote
u get reciver with it now put riciver in ps2 a port and turn it on press start button in i r controller and enjoy the GAME
5helpful
Error message Sharp FO-4450 Fax machine
Press life "2" start for toner.
And life "3" start for drum.
These will reset the counters.
If you are having a "check drum error" then you have broken the sensor arm that is attached to your lid.
Call a technician in your area.
Jeff
2answers
Faded areas showing up on copy
jhahn, It sounds like your machine needs a through cleaning from a repair company. There are many good independant vendors out there that will come out for less than $100 for a time and material call on your fax. If you want to try to do something on your own, you can take a can of air and spray the air throughout the machine. If you give me the city you live in, I can give you some ideas for some companies close by if the canned air doesn't work. john
Top Washing Machines Experts
john h
