SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
SOURCE: Krups model KM7005 water wont heat
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected].
SOURCE: B60.Coffee maker was working fine untill
Hi Bill, sounds like similar a problem I had with my Keurig Coffee maker. Your pump may be plugged with mineral deposit build-up from your water. Do you use regular tap water or filter it in any manner?
Have you ever cleaned the insides with vinegar? Empty your reservoir of water, and pour a bottle of white vinegar into the reservoir. Run the maker through several cycles to ensure the vinegar has worked its way throughout the ‘guts’ of your maker, and then let it sit for 2-4 hours.
Empty any remaining vinegar from the reservoir and then cycle at least two full reservoirs of water through to flush the vinegar out. When you stop smelling vinegar in your coffee cup, you’ll know when there’s no vinegar left inside.
You should probably clean you Keurig once a year, or more depending on how heavily you use it.
SWMBO tells me you’ll find similar instructions above in the Owners Manual or you can check out this link: http://www.ehow.com/how_4927372_clean-keurig-coffee-machine.html
Good Luck, I hope this helps! – Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
