Video Game Consoles & Games Logo
Stewart Perlow Posted on Jan 17, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace forgotten parental pin on cablevision cable box
Ray
Level 2:
Sergeant:
  • Expert 324 Answers
  • Posted on Feb 04, 2020
Ray
Expert
Level 2:
Sergeant:
Answers
324
Questions
Helped
68614
Points
727
5 Related Answers
Anonymous
  • 70 Answers
  • Posted on Jan 03, 2008
SOURCE: cable hookup and av hookup
Connect your TV to AV1 and you SAT/Cable Decoder to AV2.
on the video select the AV2 channel and it will record whatever is connected to AV2. The AV channel selected it is the input the one not selected is the output.
Some PPV Movie channels are copy protected with some service providers. But most channels are recordable.
The aerial lead coming in your house connects to the SAT/Cable Decoder 1st, then connect the output socket on that to the Video/DVD then the output on that to the TV. As long as the leads you use have different ends on you CANNOT plug them into the wrong socket. As the the aerial passes through each device, the device adds its own RF channel to the feed, so you should be able to tune both a SAT/Cable and a Video/DVD channel onto the TV set aside from using AV/Scart.
Anonymous
  • 57 Answers
  • Posted on May 31, 2009
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
Anonymous
  • 50 Answers
  • Posted on Aug 20, 2009
SOURCE: I am the forgetful parent and need to reset the
1. Turn on your Wii console and go into the Wii Options Menu
2. Click on Wii Settings and click the right arrow until you see “Parental Controls”
3. Say “Yes” to “Change Parental Controls?”
4. Click on “I forgot” when it asks you to enter your pin
5. It will ask you for your secret question, click on “I forgot” again
6. The screen will read “If you have forgotten both your PIN and secret question, call the consumer service number listed in the Wii Operations Manual and provide the confirmation number below. You will be issued a master key.”
7. Call Nintendo at 1-800-255-3700 and give them the confirmation code listed on the screen. They will give you a new Master key to enter on the next screen.
8. The PIN is now reset/disabled
Testimonial: "Excellent help and very quick. Thank you. "
Anonymous
  • Posted on Feb 23, 2010
SOURCE: How do you reset forgotten parental control password?
3308 is universal
Anonymous
  • 62 Answers
  • Posted on Sep 06, 2012
SOURCE: I've forgotten the parental pin code on my beko
yes call the guys at http://www.shopjimmy.com/ talk to them for free
I forgot childlock password in panasonic tv c400
http://eng.faq.panasonic.com/app/answers/detail/a_id/10865/~/how-do-i-reset-the-pin-code-for-parental-control-use-if-i-have-forgotten-it%3F
Online chat for support.
Instructions show above:
How do I reset the PIN code for parental control use if I have forgotten it? Please follow the steps below:-
  • Power the unit on.
  • Open the unit's drawer.
  • Select the BD drive with the Drive Select button.
  • Press and hold the REC and PLAY buttons on the front of the unit together for 5 seconds until the display shows INIT.
  • Confirm that the front display shows 'INIT'.
  • The parental PIN code has now been reset to the default code of '0000'.
How to change parental code on DSI-XL
  1. On the Nintendo DSi Menu, use the stylus to select the Settings ("wrench") icon.
  2. Select the right arrow twice to reach the third page, then select "Parental Controls."
  3. Select "Yes," to change the parental controls.
    1. You will be prompted for your 4-digit PIN.
    2. If you know the PIN, select the empty text box and enter it using the on screen keyboard, then select "OK" to continue.
    • If you don't know the PIN, select "I forgot," then select the empty text box for the answer to the secret question and enter it using the on-screen keyboard. Select "OK" to continue.
    • If you don't know either the PIN or the secret question, please click here.
    1. Select "PIN" to change the PIN or "Change Settings" to update the setting you wish to change. Once the changes are made, select "Done" to confirm any changes.
    2answers
    I forgot parental pin code, what can i do about this?
    Hi! In order to help you can you please tell me which is the software you are using?
    1helpful
    I have a Sharp Aquos 52" LC-52LE810UN. I turned the tv on and assuming that my cablevision box is working, what do I do in settings or other aspect of the tv to make the 1080i work. I have another box...
    Actually the cablevision box determines the 1080i. Once it is set on that box the television simply displays it. The cablevision box will have to be connected to the television with component cables or one hdmi cable in order for you to be able to choose 1080i on it. Usually there are resolution numbers on the side of the cable box that tell you if it's on 480, 720, or 1080. There is a red light next to the one the cable box is displaying. If this is not the right kind of cable box for that then you will need to get another one from Cablevision or just eliminate the box entirely and run the cable straight to the television. Yes you can do that and use the television's digital tuner for a beautiful, crisp picture. After removing the cable box and screwing the coax cable onto the back of the television you will have to press the input button and scroll up to TV and press enter (use a Sharp remote). Then press menu and scoll over to setup and down to CH setup. Then scroll to CH search and begin searching for the available channels. You will now use a Sharp remote to change channels.
    Forgotten pin for wii. have confirmation no
    wii pin master reset
    http://www.nintendo.com/consumer/systems/wii/en_na/settingsParentalControls.jsp#reset
    1. Access the Wii System Settings (how to).
    2. Click on the blue arrow to reach the Wii System Settings 2 menu options.
    3. Choose "Parental Controls" and select "Yes."
    4. Enter the 4-digit PIN and select OK. If you have forgotten the PIN, select " I forgot" to answer the secret question. (Answers to the secret question are case sensitive.) You will now be in the Parental Controls menu, and can change the following items:
    5. Game Settings and PIN
    6. You can adjust the "Highest Game Rating Allowed" to be played on the Wii console. This setting is based on the Entertainment Software Rating Board ("ESRB") game rating categories. Please note that Parental Controls settings do not affect Nintendo GameCube Game Discs.
    1helpful
    Forgotten pin number and question need to get new parental control number.
    Ok, when you go to enter the pin number, click "I Forgot" twice. After that, you'll see some random numbers. Write it down or something. Remember that number. Then, go to this website: http://wii.marcansoft.com/parental.psp Enter the number in the Confirmation Number box. Then, enter the date in the second box. Click Get Reset Code. Remember that number. Then, when you go to enter the pin number, enter the number the website gave you. The rest is self-explanatory.
    3helpful
    New Insignia 19 inch when hooked up to Optimum Cablevision does NOT get any cable channels..JUST basic channels...OLDER TVS all get the Cablevision full spectrum of chanels. Does it require a BOX to work...
    yes, the premium channels are in a band width only reachable with a cable box. The standard or what would be over the airwave channels are available without a "box" in the basic cable tier.
    Top BOX Video Game Consoles & Games Experts
    MegaByteMe
    MegaByteMe
    Aron
    Are you a BOX Video Game Console and Game Expert? Answer questions, earn points and help others
