SOURCE: Can I make a 99 Chevy 1/2 ton Western Unimount
No. it is technically possible but there is a good amount of metal fabrication involved.
SOURCE: my western unimount plow is stuck in the up postion. it will go down
If you mean it will not go down it is either your switch in the truck or it can possibly be the valve in the system either not working may just be sticking or it could be that its not getting the switches call to change . This is something you will have to hunt down Good Luck. If you are going to plow best learn now how to deal with al of this as it is rough on a truck
SOURCE: HOW TO GET WESTERN SNOW PLOW TO GO LEFT AND RIGHT
Hydraulic fluid doesn't really freeze. When it does, we wouldn't be around to see it. You need to go threw electrical. Go to there web site and see if you can get a diagram for it. Old systems are fairly easy to go threw. Newer ones have PC boards. Older ones, the stick/switches go bad first. But it always wise to loosen, then tighten the nuts that hold wires first. Corrosion sets in because it isn't used for so long.
If these steps do not correct the problem, you will need to re-format your External Hard Drive ***WARNING*** FORMATTING A HARD DRIVE WILL ERASE, YOU WILL LOSE, ALL DATA
