Washing Machines Logo
Bradley Burgess Posted on Jan 03, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My lg washing machine is giving a oe code. It will pause it self when it run a little bit and i could smell a burnt smell
CJ Rock
Level 3:
  • LG Master 4,429 Answers
  • Posted on Jan 20, 2020
CJ Rock
LG Master
Level 3:
Answers
4429
Questions
0
Helped
1644865
Points
15024
Https://www.lg.com/us/support/help-library/oe-error-code-front-load-washer-CT10000010-1337714738535
The machine has determined it is unable to drain water. See link.
5 Related Answers
Anonymous
  • 1036 Answers
  • Posted on Dec 31, 2008
SOURCE: Bad smell in our washing machine LG Front Loader WD-8074
You don't have to drain all the water out after each use, you just need to clean things up a bit.
There is a problem with the design, in that the drawer area is a breeding ground for mould.
There will be a latch on the drawer you need to press to remove it - take it out and wash it in a hot solution of borax. Alternatively bleach it, and then wash in hot detergent.
Use a spray cleaner designed to kill mould and mildew, and use it with a brush inside the drawer apature to remove all mould build up. It's quite a grotty job - but needs doing.
After that, use a cloth to clean as far back into the pipe as you can.
Do two washes on hot with bleach, then a rinse, and it's good to go.
It is most important you leave the drawer open after a wash, and the door open more than 2" on these machines to prevent it, and a hot wash occasionally for whites. Tell the manufacturer that you won't be buying their brand again.
Anonymous
  • Posted on May 18, 2009
SOURCE: LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
Anonymous
  • Posted on Jun 06, 2009
SOURCE: LG washing machine displaying error
It's actually a DE error code which stands for drain error. Pull the little basket out that's behind the small door on the lower left front (where the drain hose is) and look inside. The drain pump intake is about an inch in on the left. Make sure there's nothing in there like a paperclip or hair pin. If possible reach in and see if you can turn the impeller. If it won't move there's something in there if it will turn then the motor is probably bad.
worked for me
got this from mark1963
Anonymous
  • 15935 Answers
  • Posted on Sep 18, 2010
SOURCE: Im receiving an OE error code on my LG Dishwasher
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Anonymous
  • 43501 Answers
  • Posted on Nov 16, 2010
SOURCE: LG Tromm Washing Machine Won't Drain code
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
2helpful
My similar washing machine gives an OE error. It washes but won't spin giving the OE error. Please help
OE error code indicates that the washer is unable to drain the water it used during the wash cycle. OE can be triggered by a kinked drain hose or a clogged drain pump filter..... please clean drain hose back side of washing machine.. Thank you
Lg trom. It says oe
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
2helpful
My tromm LG front load washer is flashing OE, what is it.
heatman101
2answers
Every other load we have OE coming up, also the drowm will not spin
LG washing machine error code - OE
6helpful
The washer is displaying an OE. How do I fix this?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
heatman101
Won't drain during cycle, drain motor noise before stopping with OE drain error?
heatman101
My lg washer will not spin out it keeps flashing OE no matter what i do
heatman101
6helpful
Im receiving an OE error code on my LG Dishwasher Model LDF7811st. The machine runs for a little bit and then it dings a few times with the "OE" code and stops running. HELP please
1helpful
My front load Tromm LG washer flashes OE message, won't drain or finish wash. Door does open
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
