SOURCE: dwd f1011 washing machine, error codes E2&E9, machine not working
the E9 error code problem could be with door switch wiring, the door switch or the control board.but E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
SOURCE: hi we have daewoo washing machine coming error
Error code E2 is overflow problem, possibly related to the pressure switch.
If the pump runs continuously then try checking that the drain hose is not blocked or that the waste outlet is not blocked.
If that checks out OK then the pressure switch is stuck in the high level.
Take the capillary hose off from the pressure switch and blow down it to remove any residue stuck in the pipe.
SOURCE: My Haier 6kg AA washing
Hi Carys from retired Englishman in SW France,
For Haier error code 1 states 'door is not properly shut 20 seconds after program has started'
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor becoming apparent requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Hi Sayed IRFANUDDIN, we have a washing machine that was doing an e2 error and beeping and stopping while washing clothes. Mostly during the spin cycle. Check the lint filter of the washing machine is not full of lint , coins , ect
This was the case in our washing machine. The User manual might also give you clues to the cause . get the model number and search internet for user manual using the make and model number .
