Washing Machines Logo
ral jimnez Posted on Dec 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Midea Washer/Dryer Combo isn't running the dryer cycle. When selecting a cycle of wash and dry, it only displays washing time and doesn't run the dryer. Dryer works in Dry Only mode. HELP!
Your Consultant
Level 3:
Master:
  • Master 825 Answers
  • Posted on Dec 04, 2019
Your Consultant
Master
Level 3:
Master:
Answers
825
Questions
Helped
205967
Points
1873
I would suspect a problem with the control unit assuming you are properly setting it.
5 Related Answers
Anonymous
  • 1294 Answers
  • Posted on Apr 14, 2007
SOURCE: hotpoint Aquarius wd440
Find the pipe that comes out of the bottom of the drum, this may contain coin, muck, etc. Clean. This pipe leads to the small pump that draws the water out. If your clean of the pipe does not work the machine.......there could be a fault with your pump..........which you can/cannot clean.
DENNIS MITCHELL
  • 1003 Answers
  • Posted on Feb 02, 2008
SOURCE: washer dryer - dryer does not heat up
REPLACE HEAT ELEMENT TO SOLVE DRYER PROBLEM
Anonymous
  • Posted on Apr 26, 2008
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Anonymous
  • Posted on Aug 24, 2009
SOURCE: Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Anonymous
  • Posted on Dec 02, 2009
SOURCE: Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Midea washer dryer combo error code 55
AI Answer Bot answer deleted.
There is no reset button on a washing machine or a dryer. The closest to that is removing the mains plug for 5 minutes. You need a service call.
https://appliancemode.com/midea-washing-machine-error-codes/
  • E55: BLDC motor speed signal loss error.
1helpful
During the wash cycle of the 24" combo washer dryer, it leaked
A hose inside the washer is your most likely culprit. On older whirlpool washers they used a plastic hose to run from the pump to the back case of the machine that was pretty susceptible to cracking.
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Prolem drying clothes
I just contacted Samsung Tech Support for my wash/dryer combo WD-J1255C.
The reply.."it is not a full dryer ...and it is not sold as a full drier.. and don't expect it to be completely dry". I queried why it is advertised as a dryer and got the same reply.
Its a great washer but why did I pay extra for the dryer combo?
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
1helpful
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Top Washing Machines Experts
john h
