Washing Machines Logo
Uttamsingh Jhummun Posted on Dec 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung dualactive wash can not start DE error when water is full
ChinthakaJ
Level 3:
  • Master 943 Answers
  • Posted on Dec 01, 2019
ChinthakaJ
Master
Level 3:
Answers
943
Questions
Helped
301298
Points
2783
DE error is a door sensor error. try closing the door properly.
5 Related Answers
Anonymous
  • Posted on Sep 18, 2008
SOURCE: samsung washing machine ji453s
yes i did solve the problem, the water pipe leading to the sensor had a very small hole next to the clip which i disconected cut and replaced, problem solved.
Anonymous
  • 351 Answers
  • Posted on May 04, 2009
SOURCE: AFTER WASHING DOES NOT SPIN AND DOES NOT DRAIN WATER. IT SHOWS ERROR dE
that is a drain error check pump....
Anonymous
  • Posted on Sep 22, 2010
SOURCE: samsung washing machine cycle will
your door is not close right
some1cares_m
Jorgie the appliance guy
  • 5639 Answers
  • Posted on Apr 11, 2015
SOURCE: Hi I have a Samsung toploader wa75b7pt it weight the washing and sets the time period. It washes the clothes and the stars to drain the water but it then gives me a error code of de.
could be a clogged drain hose or water pump obstruction
richie46
  • 12962 Answers
  • Posted on Sep 17, 2017
SOURCE: My samsung washing machine model SW50V3 showing dE error after its full of water, its not spinning at and even not draining as well, plz help thank you.
Did you go to Samsung site and inquire re the significance of the DE error?The machine is telling you where the problem is. Use the info and check it out.
Hitachi SF-P140XWV washing machine unresponsive and display flashing
Si la pantalla de la lavadora Hitachi SF-P140XWV parpadea, es posible que se haya generado un c?digo de error. Para identificar el c?digo de error, desconecta la lavadora de la toma de corriente y espera al menos 30 segundos. Luego, vuelve a conectarla y presiona el bot?n de encendido para escanear los c?digos de error. Una vez que se haya identificado el c?digo de error, sigue las instrucciones del manual para solucionar el problema. Si el c?digo de error no se puede identificar o el problema no se puede solucionar, comun?cate con el servicio t?cnico para obtener ayuda.
1helpful
What does the error code dE MEAN
you have not said what your washing machine you have.so this is for the samsung.
If the Machine is displaying "dE" error, kindly check for the following : First and foremost the door must be properly closed. You can check the end of the drain hose is too low (Make sure the holder of drain hose in the back is intact). Also, you can check the end of the drain hose is submerged in water.7 Mar 2014
'dE' Error is displayed on the panel of the Washing Machine? - Samsung
www.samsung.com/in/support/skp/faq/135992..if yours is not a samsung then please let me know.
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
2helpful
De error code on samsung topo loader stops working
0E - OVER-FLOW ERROR
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
3answers
Wont start has error DE
Error displayed table_1.gif Solution
n_de.gif table_2.gif i_1.gif Close the door.
n_4e.gif table_2.gif i_1.gif Make sure the source water faucet is turned on.
i_1.gif Check the water pressure.
n_5e.gif table_2.gif i_1.gif Clean the debris filter.
i_1.gif Make sure the drainage hose is installed correctly.
n_ue.gif table_2.gif i_1.gif Laundry load is unbalanced; loosen any tangled laundry. If only one item of clothing needs
washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an "UE"
error message will be shown in the display window.
n_3e.gif table_2.gif i_1.gif Call after-sa
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
