SOURCE: My Front load washing machine has an error flashin...
Hello, welcome to Fixya. Since many manufacturer's use there own unique error codes, i.e. F06 on some may indicate a faulty motor, others may indicate a faulty pump for example. Can you clarify the make of your machine as well as a model number ? I'll watch for your relpy and try to assist you from there. Macmarkus :)
SOURCE: I have a Frigidaire Front Load Washer during its
The cause of the error is that no cold water is getting through the cold water valve (inside the machine).
The E10 error indicates that one of a group of error codes occurred. The specific code could have been one of the following:
To recall the specific fault code from this group, follow these steps:
Based on the specific error code, follow the specified test and troubleshooting.
The magnet for the dispenser drawer reed switch is shown in the second image below. If this magnet is missing, you will get the E14 code.
Some of the troubleshooting provided is intended for service technicians. Do not conduct any test or troubleshooting that you are not completely confident that you can safely complete. Unplug the washer before accessing internal components.
http://appliancejunk.com/forums/index.php?topic=1364.0
That website above directly addresses your issue.
SOURCE: I keep getting earth in my pool from my hayward filter
You might have torn a grid or grids in the filter when you backwashed..
SOURCE: I just got this washer
Your LF code that your getting means "Long Fill" if your water selenoids are good then
your gonna have to replace your machine/motor control assembly. Set the ohmmeter to the R x 1 scale. 4. Water Inlet / Dispenser Solenoids: Touch the ohmmeter test leads to each of the water inlet/dispenser valve solenoid terminals.
The meter should indicate between 700 and 900 ?. If the reading is outside this range, replace the valve assembly.
Hope this helps.
