Washing Machines Logo
Corazon Muoz Posted on Nov 23, 2019
What its mean of fl on my ac carrier
Fl display
makabulane maleka
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 23, 2019
makabulane maleka
Contributor
Level 1:
Answers
Questions
0
Helped
137
Points
Download pdf converter and install it, then you will get options of converting your files
3 Related Answers
Anonymous
  • Posted on Feb 15, 2009
SOURCE: my ac is carrier company window a/c its indicating {fl}
From the manual.
Message on the display(electronic models) E4 1. Failure in the inside temperature sensor E5 2. Failure in the outside temperature sensor FL 3. Dirty filter
To fix vaccume  (or wash your filter) then  hold down "Select"(or "Mode") and "-" (or "^") for 3 secconds.
agent91
Ned White
  • 2100 Answers
  • Posted on Apr 16, 2010
SOURCE: what does the red FL light mean on the display in
Some mechanic said it was a fuel injection problem, but almost always a loose connection.Prop up the tank and see if you can find something loose. Better you find it than to pay somebody to find it. Might just be a fuel injection problem, no pressure, gummed up, clogged, I wouldn't put any additives in your tank, not good, but if you do, only small amounts, burn high test. Then if all else fails, take it to the shop. Hope this helps.
John Ireland
  • 2355 Answers
  • Posted on Apr 11, 2015
SOURCE: what is FL ment in carrier window ac?
FL Dirty filter
What does the flashing FL mean?
When the Jump-Starter is fully charged, the display will read FL. Disconnect the AC extension cord from the 110/120-volt AC outlet, and then disconnect it from the Jump-Starter AC charging plug. http://www.carid.com/images/peak/info/pdfs/pkc0j6-manual.pdf
4answers
Flashing cf after carrier ac turns off
Here is an Article that I found that has some useful information for you. http://airmaster.net/troubleshooting/carrier-window-room-air-conditioner-troubleshooting CF means Cooling Fail.
Check us out online at AC Services Boca Raton
7helpful
Problem with a Condura A/C. It displays an "FL" error on the LED display. What does this mean and how do I get rid of it?
FL means, filter check warning. To get rid of it, Press the 'mode" and " " (down) buttons simultaneously for 3-5 sec.
2helpful
My window ac is showing FL mode on display. what to do?
While AC is ON, press the MODE and Arrow Down button simultaneously for 5 to 10 sec until "FL" message disappear and room temp is indicated.
21helpful
6answers
My ac is carrier company window a/c its indicating {fl}
From the manual.
What FL stands for?
FL means change filter media
Top Washing Machines Experts
john h
