Soon as i try to power it on with a swtch it blinks 1 time then nothing evan on test mode
This is an indication that the circuitry inside the unit has failed and the most common failure point is the capacitors.
Testimonial: "thank you tested capasitor your right thanks again"
My real time work with facebook Im making over $2000 a month operating low maintenance. I continued hearing distinctive people divulge to me how an lousy lot cash they can make on line so I selected to research it. All topics considered, it become all legitimate and has without a doubt changed my life. For more statistics visit below site.... www.amazon78.com
SOURCE: The printer apear to be dead!
Buttons and lights on the printer
Two buttons and three lights are located on the front of an HP Deskjet printer.
Buttons and lights
Purpose
POWER button and light
Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on.
RESUME button and light
The light blinks when there is a problem with paper. When the problem is corrected, press the button.
Print cartridge light
The
light blinks when there is a problem with a print cartridge. When the
problem is corrected and the top cover is closed, the light will stop
blinking.
Troubleshooting blinking printer lights
Blinking lights
Reason
All lights are off.
The printer is off (asleep).
Press the POWER button
to turn the printer on.
The printer should turn on automatically when a print job is sent to it.
The POWER (top) light is on.
The printer is idle.
The printer is ready to print a document.
The POWER (top) light is blinking.
The printer is busy printing.
Allow
enough time to print. When a document has many fonts or graphics or
uses complex color such as a color photo, it takes longer to begin
printing.
The PRINT CARTRIDGE (bottom) light is blinking.
Possible causes:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If
none of the above suggestions fix the problem, and, if the error
message still occurs, it may be a hardware failure. Call the HP
Customer Support Center.
SOURCE: Orange LED blinks 5 times then a 2 second green
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10239
If you type in 'flashing power light' in the problem box, for 5 you get print head failure, often it means the connectors between cartridge and print carriage are dirty, can be cleaned with a pencil eraser and a soft cloth. there is a sequence of checks and repairs to follow on the canon service page
SOURCE: sony tv kv-36fs120 will not turn on
Use a hair dryer on the back right side of unit. Humidity sensor may be causing the unit to stay off. The hair dryer may also remove dust causing a false humidity detection
SOURCE: jvc dr-mv5su blue power light blinks on and off whole machine fr
Throw the unit away its a piece of ****!
SOURCE: TV power light blinks 7 times and won't turn on
your sc bord is shot replace board and do firmware upgrade will coast about 400
