SOURCE: I have a problem with my 93 Bronco, I installed
The LED- Light emitting diodes- use very little current and voltage to light up and so when you changed from the normal incandescent type +12 , these require only a fraction of the votlage. NOW what seems to HAPPEN is that the return voltage from the switch has RESIDUAL voltage which makes the LED light up, this can be a fraction of a volt and can be a LEAK from the switches, park, brake or otherwise.
Check the wiring once again , check the ground once again and isolate the switches to confirm the LEAK. You can also use a resistor to reduce the voltage if needed which can cut off the light when switch is off.
SOURCE: Lutron Dimmer switch, single pole, will not dim
We are truly sorry for your inconvenience and want to help. Please call our Technical Support line at 1-888-523-9466 and we'll be happy to discuss the issues with you.
Craig, Lutron Technical Support Leader
