Question about Kenmore Washing Machines
My Kenmore washer, model 11049972602, beeps 3 times but will do nothing else. There are no lights on the front panel.
I had just installed a pedestal. I unplugged the machine, tipped it over on its side and installed the pedestal. I tipped the machine up, plugged it in and pressed the power button. It beeped 3 times, but no lights or display came on the front panel. I was able to enter diagnostic mode by pressing and holding any button for 3 seconds, repeating this 3 times. This is what I observed in diagnostic mode: All lights on front panel came on, Display showed C00, Display showed U01, Display showed U00, Display showed C00, Display showed n00, All lights went off except for the Modifiers lights, Display showed C00.
6ya staff
SOURCE:
Dov Dror
  • 641 Answers
SOURCE: Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
Posted on Jul 23, 2007
Anonymous
SOURCE: Kenmore Elite HE4 beeps three times when start panel is pressed and wont turn on
FWIW ... the Sears guy came by yesterday. The problem was apparently that the door latch was not operating to the extent that the sensors thought the door was open. He is replacing the latch next week. He adjusted the old one in the mean tiome and it appears to be working fine.
This kind of stunned me, since my wife reported an electric zap and the interior light burned out as the dryer went dead -- so I was sure it would be a fried circuit board -- but, no, a little jiggling of the latch seemed to clear it up....
Posted on Jul 10, 2008
Phoebe112
  • 9 Answers
SOURCE: Kenmore Elite 10.4708 front load washer won't start with new load
Uh oh! It did it again! This time I had to unplug 6 times for one cycle. Seems to be on the last 2 minutes most of the time. Today my husband is taking the control unit and looking for soldering problems. On Askmehelpdesk.com this man told of taking the bottom panel off and there is a little black latch thingy you pull to open the door lock manually. Also he said that the K2 and K4 relays are usually the problem if it isn't a soldering issue on the connectors. ( On the CCU);. He said one of them is usually burned and to clean it off and then switch it with the other one which carries less voltage, therefore doesn't burn. You can use a pencil eraser to do this. My husband told me they did this in the Army for MOose code contacts. He just told lme the soldeirng looks good on the connectors and is now working on the K2 and K4 relays. If you go to Askmehelpdesk.com/appliances you will see these tips are for the Whirlpool Duet whic is apparently the same machine as our Sears Kenmore H4's. Gosh, I hope this helps someone as it sure is not fun trying to track this problem down. I am glad you got Sears to come out. I will NEVER and I repeat NEVER buy from Sears again! Did I mention I wrote a letter months ago when I was having a hard time getting warranty work done.( Which I never did) that I had written to the pPesident, CFO and the Texas Attorney General for Consulmer Protection Division and never got a response from anyone?
Posted on Feb 14, 2009
erica graber
  • 530 Answers
SOURCE: HE4T will not enter diagnostic mode
usually if it's you motor controller it should stil go into diagnostic mode. so that is probably not your problem. can you post a picture of the inside ccu board and of the door lock this would be helpful.
Posted on Apr 22, 2009
Anonymous
  • 116 Answers
SOURCE: our machine's digital display reads 'dE' seconds after pressing start and nothing isour machine's digital display reads 'dE' seconds after pressing start and nothing is happening except for an awful b
try to close dorr completely if not call in service tech.
Posted on Apr 29, 2009
Pedestal 46262
How do you mount base to washing machine?
Jan 08, 2014 | Kenmore HE2 Plus Front Load Washer
Can I use a frigidare pedestal model number apwd15w fit on a kenmore model number 41122
Good Morning Kristy, thank you for your question!
Because pedestals are designed specifically for the manufacturer brand appliances, I am unable to guarantee it is compatible for installation with a different brand as the dimensions and other specifications may vary.
Best regards!
Dec 02, 2013 | Frigidaire GLTF2940ES Front Load Washer
How do I change a crank sensor on a 1998 Buick Lasabre?
1998 Buick Lesabre 3.8L SFI OHV 6cyl
The dual Crankshaft Position (CKP) sensor is mounted to the front of the engine, attached to an aluminum bracket mounted to the left side of the engine at the timing chain cover. A 4-wire connector plugs into the sensor, connecting it to the ignition control module.
Fig. 1: The Crankshaft Position (CKP) sensor is mounted to the front left side of the timing chain cover
REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Remove the serpentine drive belt from the crankshaft pulley.
  3. Raise and safely support the vehicle.
  4. Remove the right front wheel and tire assembly and the right inner fender access cover/splash shield.
  5. Using a 28mm socket, remove the crankshaft harmonic balancer retaining bolt.
  6. Remove the crankshaft balancer, using a puller if necessary.
  7. For 1992-99 vehicles, remove the CKP sensor shield.
Fig. : If so equipped, remove the crankshaft position sensor shield
  1. Unplug the sensor electrical connector.
  2. For 1987-91 vehicles, perform the following:
    1. Remove the sensor and pedestal from the block face.
    2. Remove the sensor from the pedestal.
  3. For 1992-99 vehicles, remove the sensor from the block face.
To install:
  1. For 1987-91 vehicles, perform the following:
  2. Loosely install the crankshaft sensor on the pedestal.
  3. Position the sensor, with the pedestal attached, on crankshaft sensor installation tool J 37089 or equivalent.
  4. Install the bolt to hold the pedestal to the block face, then tighten to 14-28 ft. lbs. (20-40 Nm).
  5. Tighten the pedestal pinch bolt to 30-35 inch lbs. (3-4 Nm).
  6. Remove the special tool.
  7. Place the crankshaft sensor tool on the crankshaft balancer and turn. If any vane on the harmonic balancer touches the tool, replace the balancer.
  1. For 1992-99 vehicles, install the CKP sensor on the block.
    1. Install the retaining bolts and tighten to 14-28 ft. lbs. (20-40 Nm).
    2. Install the crankshaft position sensor shield.
    3. Attach the sensor electrical connector.
  2. Install the balancer on the crankshaft.
  3. Tighten the crankshaft bolt to 200-239 ft. lbs. (270-325 Nm) for 1987-91 vehicles. For 1992-99 vehicles, tighten to 110 ft. lbs. (150 Nm), plus an additional 7 degrees rotation.
  4. Install the inner fender shield and the right tire and wheel assembly.
  5. Carefully lower the vehicle.
  6. Install the serpentine belt.
  7. Connect the negative battery cable.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jan 23, 2012 | Cars & Trucks
Our front load kenmore washer is not draining properly at the end of the wash cycle. At the end of the wash cycle it sounds like it is trying to drain but it does not even spin. Then it seems to run water...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 31, 2011 | Kenmore Washing Machines
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
Details dimensions of clothes washer for the bleends at the back for ducting porpose.
Factory-supplied
equipment
There is a packet of accessory parts supplied with your washer. Check that all the accessory parts supplied for your model are there. If any parts are missing contact
your dealer immediately.
Inside the drum
Water supply hose for cold water (blue marking).
Water supply hose for hot water (red marking).
Water drain hose.
A bag which contains
Covers to be placed over the holes for the transport bolts (after removing them).
Clamp for drain hose.
Wrench for levelling.
Elbow for attaching the drain hose, e.g. to a sink.
Depending on the type of connection, the following may also be required
Y-connector (can be obtained from any hardware store) in case there is only a cold water
connection available.
Any residual moisture inside the drum is due to the final testing which every washing machine
undergoes before leaving the
factory.
On the rear of the appliance
Power cord with plug.
C = cold water connection
H = hot water connection
Useful tools
The following tools are helpful
Box cutter.
Flat head screwdriver.
Closed wrench (1/2"/13mm).
Bubble level.
Dimensions
a = 27.0 inches (686 mm)
b = 30.7 inches (780 mm) c = 37.0 inches (940 mm) d = 16.0 inches (407 mm)
Door opening angle 180
Approx. weight = 220 lbs (100 kg)
Installation area
DANGER
Never ground the washer to plastic plumbing lines, gas lines or hot water pipes.
Appliance stability is important, otherwise the washing machine could "walk" during the spin
cycles.
The installation area must be solid and even. Soft floor surfaces, such as carpets or surfaces with
foam backing, are not suitable.
If the washing machine is to be installed on a weak wood floor consider the following
0 If possible, place the washing machine in a corner of the room.
0 Screw a water resistant wooden board (at least 3/4" thick) to the floor.
0 Secure the feet of the washing machine with holding brackets. Order the holding brackets (set)
from Siemens Customer
Service (WMZ 2200).
Pedestal Mounting
If mounting the washer on the Siemens pedestal (accessory
no. WZ20395) follow the instructions supplied with the pedestal.
if Install pedestal prior to removing transport bolts.
Closet
If installing the washer in a closet,
observe the minimum distances according to the following table
Minimum Installation Clearances
Closet
Sides 1/4" (6 mm) Top 12" (305 mm)
Rear 2,5" (64 mm) Front 1/4" (6 mm)
Ventilation
Top 48 sq. in (310 sq. cm),
Bottom 24 sq. in (155 sq. cm)
Jan 03, 2011 | Siemens WFXD5200UC Front Load Washer
LG washing machine WM2277H tub off center does not spin electronically, manually its spins but rubs sides
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 02, 2010 | LG WM2277H Front Load Washer
Installing pedestal to washer
You want to level just the pedestal in the place where you will be using it so when you put it in position mounted together later it is done. Also very easy to do first. Get the pedestal level, tighten the lock nuts, put the washer on its back. Usually you remove the washer feet, take the pedestal drawer out, screw on each side, bolt the pedestal to the washer with the four screws provided. Tip pedestal and washer up, on to something that slides easily to protect floor. There usually are some type of shipping bolts that have to be removed from back of washer before using on new units. Usually four and these have to be removed.
Jan 13, 2010 | Maytag EPIC MFW9700S Front Load Washer
How do I level my machine with an accessory drawer underneath?
Do not try to level the washer. Level the feet on the pedestal AFTER the washer is installed. Just make sure the legs of the washer are all set the same on the pedestal and tightened down. Then, adjust the pedestal feet so the washer is level front-to-back and side-to-side. Once you level the unit, place your hands at opposite diagnoal corners on the top of the washer (one hand on a rear corner, the other hand on the front corner). If the washer has a firm foundation and you have the leveled the feet correctly, it should not move when you apply any pressure at these opposite corners. If you have questions, please let me know. I hope this helps you.
Nov 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
How do we install the pedestal to the front load Kenmore washer
The pedestals bolt into the bottom of the washer where the legs where.
This is definatly a heavy job, so it's best to get 2 more people to help you out.
#1 Remove all 4 legs that came on the washer factory.
#2 Make sure you have enough room to manouver the machines. The washer is going to be the most difficult so start with it.
#3 Have your friends tilt the machine back and you slide the pedestal under the machine.
#4 Kneel down infront of the machine to prevent it from sliding forward.
#5 Have your friends lift up the back of the machine and walk it forward until the holes in the top of the pedestal are in line wiht the holes from where the legs where.
#6 Thread in the bolts and tighten.
**You will need to take out the drawer of the pedestal to get the back bolts in. There are plastic clips on the inside of the runners, just push those down at hte same time and pull the drawer**
Good luck! Please let me know if this was helpful!
Oct 03, 2009 | Kenmore 15.5 in. Pedestal
Washing Machines Logo
49 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
