I keeping getting message "motor fault drive" model of the washing machine PW6101EL, i replaced drive and the fault still coming up also i check the tachometer and is look ok.
    Top Expert:
  • Washing Mach... Master
  • 30,690 Answers
Check for worn brushes in the motor.
Posted on Oct 15, 2019
6ya staff
SOURCE:
Colin Stevens
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
fixer444
  • 106 Answers
SOURCE: washing machine keeps stopping mid wash and coming
Hello
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Posted on Feb 27, 2009
Anonymous
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
puposet
SOURCE: f-02 fault code on indesit we16 washing machine
For what it is worth my WE16 often stops with an F-02 display within 3 minutes of starting, but only in summer months. Powering off and restarting usually cures it, and it will then go on to run several loads without problem. I keep the machine in my cellar boiler room, and attribute the problem to high humidity when the boiler is not running. Changing the PCB does not cure the problem, nor does protecting it against humidity (eg poly bad and silica gel). I conclude that moisture getting somewhere unexpected (tacho perhaps?) can cause this error.
Posted on Jun 12, 2010
db82919
SOURCE: Asko W640 Front Loading Washing
check the brushes on the motor $20? can get them from asko. most everyone will try to sell you a motor $$$
Posted on Jun 27, 2010
I have a samsung front loader WF7700N6W1 WHICH KEEPS COMING UPWITH THE ERROR CODE 3E IVE checked the drainage plug and cleared that but mavhine still not working.
The 3E error code to indicate a drive motor tach fault.
Here's a good website that discusses how to troubleshoot and possibly repair. (Could be as simple as unplugging the machine for a few minutes).
How To Fix 3E Error Code On Samsung Washing Machine
Here's an EXCELLENT YouTube video on removing the motor and replacing the brushes (if equipped).
Samsung Washing Machine 3E Error Code not spinning or turning
Jun 15, 2017 | Samsung Washing Machines
Model wf361. What is causing e3 error?
e3. Drive motor tach fault. This means that the tachometer is not regitering any motor movement when it should. Main reasons for samsung: motor control board fault. Tachometer fault. Motor fault. Also check wireing from motor control board to motor. But this issue is not common at all with samsung.
Feb 15, 2016 | Samsung Washing Machines
Model pw6065. Why is 'technical fault' displayed?
Hi dear. Machine display that message because,there is a problem with machine's components - drive system etc.. Which is not rectified by user. (You can check the fluff filter but you can not test the motor or electronic board.)You need to get professional help from Miele for proper diagnose and solution for it. Thanks.
Jan 30, 2016 | Miele Washing Machines
The SE light flashes when turning on the washing machine
Not sure which washing machine you have. But assuming it is an LG SE is a serious fault.
Motor fault detected Can also be caused by be main PCB
This is not a good fault code to see as it will generally be correct and either the washing machine drive motor or the main electronic control PCB is faulty.
  • Check motor
  • Check motor tacho
  • Check all connections and blocks to the motor
  • Check connections on the main control module
  • Check main control module
For more detailed analysis please post make and model of your washing machine in the comments field.
Sep 26, 2014 | Washing Machines
Error code f 07 mid cycle?!?
You do not state your machine or model. The error code F07 that I have states that the Central Control Unit has detected a short in the Motor Control Unit.
Check the wire harness between the Drive Motor and the MCU and between the MCU and the CCU.
Check the MCU.
Check the Drive Motor.
Check the entire wire harness.
Replace any defective parts.
Apr 26, 2011 | Washing Machines
My machine keeps displaying a E9 fault, what should I do to repair this?
You have not mentioned the make and model. Now the error is an indication of the fault or a protection indicated.
So remove power and plug in after making sure the door is shut - the door switch is checked to work.
If the error comes on , check on the power to the control panel, observe board for visible damage, check the inlet valve, check for working, check the drive motor, capacitor and drain pump/valve. Once confirmed that all these are working check for line break , if there was damaged done by rats/insects.
If none of these show an indicative fault then the program controller can be faulty.
Apr 11, 2011 | Washing Machines
Error message F 11
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential causes: • Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU) (its the
usual thing)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component. Check for sharp edges in wash basket of machine. Companies want you to dump your machine & go for a new one, keeps their factories running.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
this clicking of the timer tells you there is a fault somewhere, this could be anything, you have to check things i would do them in this order check the heater element, most common fault second the pump but you said that works then check the motor that drives the drum belt look at the motor control board for any signs of burning etc, this could indicate a motor fault you have not given much info, but with a fault like this thats all you can say, i have given you a brief starting point what and where to look, so happy hunting if i can be of further help get back to me
Oct 06, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
