Electrical Supplies Logo
R
Robert Zakrzewski Posted on Oct 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New home and new microwave on its own circuit. It trips the GFCI breaker. Tried on other GFCI circuits and it trips them too. Does not trip non-GFCI breaker. Any thoughts?
sherlywang
Level 3:
Master:
  • Electrical S... Master 428 Answers
  • Posted on Oct 16, 2019
sherlywang
Level 3:
Master:
Answers
428
Questions
0
Helped
198370
Points
1063
If you more help or purchase diesel generator set, please visit at www.dieselgeneratortech.com.
5 Related Answers
Jimster
James Greene
  • 240 Answers
  • Posted on Feb 02, 2008
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
ussmarc
FIRE ALARM SYSTEMS
  • 26 Answers
  • Posted on Jan 31, 2009
SOURCE: LG washing machine trips GFI Circuit Breaker
WASHING MACHINES ARE NOT TO BE CONNECTED TO GFI OUTLETS AND TRY TO CONNECT IT TO A CERCIUT THAT IS NOT WITH YOUR DRYER. (REG) OUTLET.
Fahr Quad
  • 776 Answers
  • Posted on Feb 27, 2009
SOURCE: Ground Fault circuit Breaker trips each time a load is applied
The most likely causes in their order of probability are: 1) water somewhere in the circuit causing the hot wire to ground; 2) a legitimate trip caused by a defect in a device plugged into the circuit; and 3) a defective GFCI breaker. In the first case, wait until it has been dry for about a week and see if it trips. In the second case, make sure there is nothing plugged into the circuit and try resetting. In the third case go ahead and put the regular breaker in, then put a GFCI outlet into the first box downstream from the breaker. If installed according to the directions, that outlet should protect all of the outlets downstream.
Anonymous
  • 57 Answers
  • Posted on Feb 28, 2009
SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
Anonymous
  • 1489 Answers
  • Posted on Aug 20, 2009
SOURCE: electric lawn mower repeatedly trips house circuit breaker
The breaker is tripping because there is a short in the mower electrical circuit -- most likely in the motor winding -- it overheated.
If you have a multimeter measure the resistance (ohms) of the motor winding by putting the meter probes on the two flat prongs of the power cord with the mower switch on. If you get near zero ohms, the winding is shorted -- motor "burned up".
Using the multimeter again, check for continuity between the round ground pin on the power cord and each of the two flat prongs. If you get continuity on either of these, there is a short to the mower chassis. This can probably be corrected without much expense.
My bet is on the motor winding being shorted.
Charlie
White springs spa wiring diagram and troubleshooter
120Volt or 240Volt?
Hardwire or plug-in-outlet?
Where is the GFCI? On the outlet or on the breaker?
Here is a starter:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Are you connecting a new spa?
Or is old spa having problems?
Exactly which problems?
Or if the element getting wet and causing GFCI to trip?
Is circuit breaker tripped?
Add a comment for live response 11-7-12
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 06, 2012 • Pool & Spa
20 A AFCI Homeline trips intermittenly on a outlet circuit with no lighting on it. The circuit does have an GFCI outlet on it. Trips mabe once a week. replaced the breaker and it worked fine for about a...
You should not have multiple GFCI devices in any one circuit. Change out the outlet and label it
GFCI Protected if necessary...Your problem of nuisance trips should go away.
John
1helpful
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
I''ve gotta small issue with an electrical outlet in my kitchen. I've got a GFI that is connected with two additional outlets as would be the norm. I was having a problem with the GFI popping every once in...
GFCI receptacles are polarized and connecting them correctly is critical. The hot wire should be black, blue, red, etc. The neutral should be white or natural gray. The ground should be green (if equipped).
Also, it's common to have other receptacles in a kitchen wired "downstream" of a GFCI so that if the GFCI trips or there is an issue with another non GFCI outlet, you're still protected.
Check all outlets in the kitchen and be sure they are wired correctly and in good shape. Unplug everything while you test. If the GFCI still trips, start looking for loose neutrals or bad ground wiring (or no ground) at the other receptacles since you said you already checked the breaker box.
A coffee maker can be a cuplrit that causes a GFCI to trip since it is a heating device and uses water, which can make them more susceptible to electrical problems. Check the microwave too (if equipped).
3helpful
2answers
Keeps tripping circuit breakers bunn NHb
Hello
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
John
1helpful
Trips GFI circuit brakers
First of all, lets clarify what is going on. You say it trips the GFI breaker, so I'm assuming that it is not a GFCI receptacle that you are plugging into. So you are going to the electrical panel and resetting the GFCI breaker.  If it were a GFCI receptacle, have you tried other loads in this receptacle for 30-40 seconds, ie: Toaster, hairdryer, coffee pot? If everything works fine then there is something wrong with the ESP8XL. It would seem that there is a leakage path to ground from one of the conductors. If it is new, bring it back.
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
2helpful
Top Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
