Question about Refrigerators
Refrigerator gets too cold even at warmest setting. Vegggies freeze as well as pasta and beverages. I have a top freezer unit.
    Top Expert:
  • Refrigerators Master
  • 85,223 Answers
Need make and model of product.
Posted on Oct 08, 2019
6ya staff
SOURCE:
Anonymous
  • 1122 Answers
SOURCE: jenn-Air Refrigerator JCB2059GES freezes
your thermostat is bad,get the model number from inside and call your local appliance store and get a new one,let me know,thanks-mike
Posted on Jun 23, 2008
SOURCE: Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Posted on Nov 05, 2008
Anonymous
  • 531 Answers
SOURCE: Food in Chef's Pantry drawer freezes, even on warmest setting
check the cold control or the door is not closing proper
Posted on Apr 01, 2009
Roipatrick
  • 906 Answers
SOURCE: Kenmore 596.72913200 refrigerator cold, freezer cold but not freezing
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
marka19
marka19
  • 1430 Answers
SOURCE: Water is leaking and freezing
The problem is the drain is clogged. Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½" in diameter this is the drain tube. Try using a turkey baster to flush out the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. After cleaning mix a 50 -50 solution of baking soda and water and run some down the drain tube this should help prevent future clogs. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Posted on Feb 02, 2011
I have a Crosley top-freezer refrigerator and the refrigerator is fine but freezer is much too cold, even at the warmest setting
i dont see how a freezer is to cold? but if it is always running you will need a new cold control
Oct 03, 2013 | Crosley Refrigerators
Why do freezer coils ice up on my Stainless Steel Whirlpool refrigerator (model GB2SHDXTS)?
On your model your cntrl board has a relay that can stick causing the compressor to always run even when the unit is turned off or in defrost. turn the fridge off, move the temp of the freezer to it's warmest setting and it should display a line in the freezer and fridge temp display. listen to hear if the compressor is running in back of the unit. if it is you need part number: 12868513
Mar 15, 2013 | Whirlpool Refrigerators
Our Amana bottom freezer refrigerator is too cold in the refrigerator portion. It keeps freezing all the fruits and vegetables even though the temperature is set on the warmest setting in both the...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 11, 2011 | Amana ABB1927DE Bottom Freezer...
My refrigerator is too cold. It is on the warmest setting on both the freezer and refrig yet the lower draws freeze. Got any ideas? And yes the compressor is not running all of the time.
by setting the freezer control to the warmest setting you allow the maximun amount of air into the refrigerator. set the freezer control to the center location.
Mar 28, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
In the house we just bought there is a copper brown top freezer Frigidaire which says it is a Deluxe 17. Cleaned it and plugged it in. Set freezer unit for "normal:" and refrigerator on...
Freezers only buils up layers of ice after multiple opebing and closing of doors allows fresh air inside, the moisture then freezes out of the air and builds up in layers on the cold surfaces. Note that the more ice that builds up decreases the efectivness of the freezr and thus costs more to run. To test try making ice cubes in atray. The number 1 setting on the fridge will be the warmest setting. Hope this helps.
Sep 29, 2017 | Frigidaire 16.5 Cu. Ft. Top-Mount...
My refrigerator keeps freezing on the refrigerator side
your damper door is frozen fully open between the refrigerator and freezer compartments and letting in too much cold air even though the temp setting is set on warmest setting,defrost it and then adjust the cold control and see if it moves again,if it freezes often the door seals may be letting in warm air from outside,condensing and freezing things up
Jan 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
