SOURCE: Garbage disposal will not go on. Breaker is on, reset has been tried.
Yes. It is possible. Is the push button in with this switch box? Because the push button could be bad.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jay_17408fb1a2cad107
SOURCE: My garbage disposal works but the water in the
Put a pail under the trap and empty and clean it check for leaks after reinstalling Does the disposal make noise like it is running ?
SOURCE: reset button leaks every time I use the disposal
The internal seal is leaking and the unit must be replaced or repaired. Call this number 1-800-558-5700 and have the model # and serial # ready for the call. Explain where the leak is happening and see what they say. They may give you a new unit or repair it at no cost depending on how old it is. Unplug & Stop using the unit until you get it repaired as this is a dangerous situation. If you can get no help from InSinkErator then just buy a new one and toss this one out.
SOURCE: my garbage disposal won't run,
If your disposal is just humming then it is jambed. You need to take a Allen wrench under the disposal and un jamb it. Center of the disposal on the bottom is where you will put the wrench and turn it back and forth to un jamb it.
Or on the link below on page 10 will tell you how to unjam.
http://www.insinkerator.com/pdf/US_ICU1.pdf
Good luck and please accept the answer
