Need manual for LG Tromm WM2277HS. Keeps showing error code LE 1 minute after it starts
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
LE code is for an overload in the motor. Restart the cycle in 30 minutes. If LE is not released call for service.
how to remove backside to check the power cord
