The choke of any engine should be set to "closed" during startups and then moved to "open" once the engine warms up. Depending on the style of your generator, this choke lever may be positioned in a few different places. On many generators, it can be found directly above the air filter on the side of the unit. On others, the choke is builtin to the power control knob (such as with the WEN Inverter series). Either way, it should be set to closed (also referred to as the start or the choke position) when starting the generator. Once the engine ignites, move the choke to the ON/RUN/OPEN position for operation. If the engine is already warm (for instance, if it was running for a while and you are refueling), the choke lever should be set to the RUN (open) position for starting.
or
If the gas tank is full, but no fuel is getting to the carburetor, there may be a problem with the fuel line or fuel valve. The fuel valve controls the flow of fuel from the gas tank to the carburetor. Make sure that this is set to OPEN to allow fuel to flow into the proper channels. If the valve is set to OPEN but the fuel still does not properly flow, you can do two things. First of all, if there is a vacuum relief valve on top of the gas tank, make sure that it has been opened. Secondly, unplug the outlet hose from the intake side of the fuel valve to see if gasoline is freely flowing or not (have a bucket ready in case the gas flows fine). This will help you determine what part of the fuel line (if any) is clogged up. If there is an in-line fuel filter between the fuel valve and carburetor, also check it to make sure it is not blocked.
SOURCE: spark plug gap keeps closing on 2 stroke engine
it could be the spark plugs are to long and the piston is hitting the glug
SOURCE: Generator won't start
After removing the carb, disassembling and blowing it out (twice) to no avail, got a one gallon can of Gunk Parts and Carburetor dip. Removed the carburetor (again), removed float bowl cover, gasket, float, and needle valve and soaked it in the cleaner for several hours. Blew it out (again) and reinstalled it. Now generator starts on first pull like new!
SOURCE: tappet clearance and spark plug gap on 5.5 hp ohv
I have a Robin but they all are pretty much the same for plug gap and tappets. I worked in a lawnmower small engine repair shop for many years in San Diego
I set them all the same and never had one return. I just did mine a couple of months ago and hand lapped the intake and exhaust valve seats. Starts first time everytime like the 7.5 year old unit is new!!!
Plug gap 0.19
Tappets
Intake .005 cold
Exhaust .006 cold.
SOURCE: i have no fuel at
Make sure you have flow from the tank to the carburetor. Also, when you cleaned the carburetor, there are several jets that have to be open in order for the fuel to "flow" through the carburetor. The carburetor on this generator has a pilot jet located on the top side of the carburetor and a main metering jet that screws into the very bottom of the carburetor and will be visible when the bowl is removed. After the main jet is removed there is a main nozzle that also has holes in it that have to be open also.
Another problem that is possible is compression. If the engine does not have sufficient compression it will not "pull" the fuel into the combustion chamber on the intake stroke. Hope this helps to get you in the right direction.
SOURCE: Just bought a Homelite 2500
Lets cut to the chase here.
I know the engine replacement part number is: 309591038..... BUT, I do not know what engine this is. There is an ENGINE number some where on this engine that I need to help you. Usually it is not to far from the oil dip stick area on the base of the engine. If you would plese pass me the engine number so I can help you.
Kellu
