SOURCE: my hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
SOURCE: frigidaire washing machine no spin cycle
I had the same problem with my Frigidaire Affinity front load washer. It would go through the wash cycle but would not do the final spin cycle that takes the access water out of the clothes. It would actually cut off when it got to be 6 minutes left. I checked the hoses, belt, motor and pump but all were functioning properly. I even cleaned out the filter thats located in front of the water pump. It was full of coins and other debris but it still didnt fix the problem. I called the repairman and he concluded that the control board was bad and would have to be relaced. The board is $200 and labor $140. It will cost you $340 dollars to correct this problem unless you know how to replace the control board yourself. Only had the washer for 3 years. I wouldnt expect something like that to occur within that short period of time.
SOURCE: burning smell during spin cycle on frigidaire washing machine
Open lid as you would load clothes and hold the inner drum with all the holes in it. Give it a manual turn left, then right. If it spins in both ways the main bearing is gone. This is not a DIY because the new bearing has to be pressed on at a machine shop, or an appliance repair shop.
SOURCE: My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Hello sismurphy1 - Does the washer make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately.
