On your Visio TV remote control there will be a Source button or Input button. Press it & on your TV screen select HDMI 1 or HDMI 2. See the TV to see how the HDMI cable is connected from TV to Set Top Box. Now take the other remote control i.e. Sony Universal remote in your hand. Press mute & Select simultaneously. A blue light will blink twice, Immediately release the buttons & enter the code. You have to be extremely fast in doing this.
Following are few codes which you can try:
002, 000, 011, 080, 111, 006, 071, 128, 1904, 925, 0000, 0834, 0810, 1685, 1786, 1032, 1972.
Check the Visio TV manual for the make of your TV & model no & if code is printed. Then contact Visio TV manufacturer or retailer for the Visio TV code to enter & synchronize with the Sony Remote Control.
Our Visio 42" flat screen TV did the same thing. It didn't happen that often but sometimes it would go darker or the sound would go off until I changed the channel or turned TV Off then back On. I contacted Visio through my warranty and they sent me a flash drive to install info on my TV. Did not fix the problems. A year later before warranty ended I contacted Visio again. They sent a huge box for me to pack my TV in to send to the warehouse where they fix everything. It took about 2 wks. to get it back. Worked fine for about 4 months and the problems continued. I will not buy another Visio TV. I found out that they had many problems with several models.
If you can get into the setup program, try doing a factory reset to get back to the default setup settings. This may cause you to lose apps that you have added to the set, however, but that's better than having to buy a whole new set. You also may want to see if there are any updates for the set from Visio if you don't have it set up to download and install them automatically already.
Hello there, the probability of 2 Vizio LCD's having the same problem is quite abnormal. The problem is definitely from the cable box as LCD TV's are usually factory tested to ensure that such problems dont exist in the unit. Check the cable box and also check the cables with which the cable decoder is connected to the TV. This is where your problem is from. Hope this support has been helpful? Thank you for visiting FixYa.
Did you continue to go through the code search? Chances are there is more than one code in the remote that will work with your tv and may have more or less functionality. I would give that a try first.
