Here is a link to a manual that may help you
https://www.manualslib.com/manual/68894/Homelite-Hl2500.html
SOURCE: no power
why didnt you hook it up to your wiring harness and were is the red wire hooked up the yellow is the memory wire make sure you have a good ground
SOURCE: want to wire up toggle switch to run turn signals
WEll, that is one idea, but I reccomend against it, as the brake light system is tied into the circuit, commonly. Just fix the t/s switch.
SOURCE: which post is which on generator on a 1975 sportster?
the post should be the same as an original. The wires should be green and tan. Green wire goes to the post towards the front wheel and the tan to the post nearest the engine. Don't forget to "polarize" the generator before starting. procedure is in the service manual. Momentarily short between the battery positive post and the field terminal.
SOURCE: Main burner will not lite. Jumped "TH" wires on
Follow the wire down to the front of the cabinet and you should find a black section about two inches long. Jump past this and see if it fires. This is a wax roll out switch. If the fire comes out the front of the box this switch will melt and shut the heater down. If the black is loose it's probably OK. If it is tight on the wire it has gone bad.
This protects the rest of the heater from flame roll out so if it has gone bad you need to check for the reason it did.
A kill switch wire works by stopping power to the switch by connecting to ground..usually the engine..but any unpainted surface will do..just make sure it is a clean contact and tight..good luck..
