Coleman Powermate Powermate 5000W Generator Logo
Posted on Sep 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Generator motor runs fine, not getting electrical power, reset buttons seem ok, has not been run for more than a year
Anonymous
Level 2:
  • Expert 86 Answers
  • Posted on Sep 10, 2009
Anonymous
Expert
Level 2:
Answers
86
Questions
Helped
32707
Points
132
You may have a bad cap or two on the inside
  • michael bolton
    michael bolton Feb 18, 2024
    Take a 12v car battery and arc across the windings momentarily a couple times. Should be able to do this on the front cover of the generator. Should be. A couple contacts.
My Powermate 8750 does not put out electricity! I checked the brushes seem ok? Tried flashing it at the brushes but not even a spark?
If the motor runs AND there is no electricity the power regulator modul can be damaged by faultering slide contacts or overload, if there is no circuit breaker protection is to find, a power assembly if there is used or a capacitor damaged.
1helpful
Porter Cable BSI550 W 5,500 Watt Generator With 10 Hp Engine No AC output
Sounds like the generator unit (sometimes called the generator head) has overheated and melted the insulation in the windings. This is the same as an electric motor "burning out", and if this is the case, then the generator is toast. If you happened to notice that the lights or fans were getting dim or slowing down before the breaker tripped (without the gas engine slowing down) then this is most likely the case and you generator is toast. But if the output just suddenly quit, then it is possible that some smaller electrical component has failed. In any case, it's not something external that you can easily reset or replace. Sorry for the bad news.
Ex 5000 sx generator, no power
Hello dear, would you consider buying a new generator? Generator Diesel Generator Cummins Generator Volvo Generator Perkins...
If you can start your generator normally, you can analyze the reasons through the following article:
Why Diesel Generator Fail to Start
Simple Ways to Deal with Diesel Generator Failure
Hope it works for you.
6helpful
2answers
8helpful
5answers
Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
Top Coleman Electrical Supplies Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
