Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
First of all have you noticed whether the noise happens through the wash cycle or when it drains the water? If its the former then it will be in your wash motor, the later in your drain pump.
Have you noticed whether a drinking glass was cracked or broken when you emptied your dishwasher?? if so it could have found its way into the wash motor or drain pump.
If the noise is high pitched ( like a saw mill) it is most liokely to be a wash motor bearing thats failed. If so you are looking at a new circulation (wash) motor.
SOME DETERGENT DISPENSERS ARE ACTIVATED BY A SOLENOID THAT IS ELECTRICALLY CHARGED. IT WOULD BE POSSIBLE THAT IS WHERE THE NOISE IS COMING FROM. IF YOU WANTED TO CHECK, REMOVE THE DOOR PANEL AND SEE IF THERE IS A ROUND ITEM AT THE DISPENSER ASSEMBLY WITH TWO WIRES ATTACHED TO IT. PUT THE DISHWASHER INTO A CYCLE AND WHEN THE NOISE APPEARS, GENTLY PRESS ON THE SOLENOID TO SEE IF THAT IS WHERE THE NOISE IS COMING FROM. REPLACE THE SOLENOID TO SOLVE THE ISSUE.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
try washing on hottest cycle it may be the seal in the spray pump somethimes the rinse aid can put a glaze on the seal if that doesnt work you can replace just the front part of the motor( in australia) dont know where you are.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
