there are too emergency stop sensors on generators
one is over load
the other is low oil level in the sump (Low oil pressure)
That sensor is known to trigger and activate the emergency stop so check it out after you check the oil level in the sump
to reset any shutdown code on units 2010 and newer, switch generator to 'off', press 'enter'. this will clear the code, then you can attempt to start by switching to manual.
The pull cord is like a starter on a car (separate
from the motor/engine). If the pull cord will not turn it could be because the
motor/engine is seized.
check the reset-- if power to reset line, switch bad if no power -check feed out from generator if no out put then possible internal problem --winding or short
Yes, there must be a protection device on the unit somewhere. It should be indicated in the owners manual. It may be on the box the outlets are in, or built into the cover of the generation unit.
