Review this information and links:
Trailer 4 Way System Diagram-
Accesories and InstructionsInstructions
1.) Determine a suitable location for mounting the circuit protected
converter in an out of the way spot near the left tail lights in the trunk or on
the frame rail, if mounted under the towing vehicle.
2.) Ground the white ground wire by placing the ring terminal under an
existing screw attached to a clean metal surface or by drilling another 3/32"
hole and using one of the self tapping screws provided.
3.) Disconnect the tow vehicle's negative (-) battery cable.
4.) Cut the in-line fuse holder loop wiring.
5.) Using a ring terminal (3/8 inch for top terminal or 1/2 inch for side
terminal), attach an in-line fuse holder (with fuse removed) to the positive (+)
terminal of the battery.
6.) Route black 12 gauge wire from the fuse holder to the converter
passing under or through the vehicle.
Note: When passing the wire through sheet
metal always go through an existing grommet, add a grommet or use silicone
rubber to insulate the wire from the hole.
7.) Attach 12 gauge wire to the fuse holder with the yellow **** connector.
8.) Reconnect the tow vehicle (-) negative battery cable. Note: See tow
vehicle owners manual for any special battery reconnection and instructions.
9.) Determine if the towing vehicle has a 2 wire or 3 wire system.
2 Wire System
- Has same bulb for stop and turn signals.
- Some vehicles have a separate bulb for stoplights but also have a
combination bulb for turn and stop. These cars should be wired as 2 wire
systems, using the wires going to the common bulbs.
- Note: Attach the crimp on spade terminal provided to the red stop
wire and ground it along with the white wire.
3 Wire System
- Has amber turn signals, separate.
- Has separate bulbs for stop and turn signals (both red).
- Note: Attach red wire to tow vehicles brake light circuit.
10.) Using a circuit tester or volt ohm meter (VOM), determine which wire
attached to the left taillight assembly is the left turn wire. Attach the units
yellow left turn wire to this wire using one of the blue wire taps provided.
Determine which wire is the taillight circuit and attach the module's brown
tail / license wire to it with a wire tap. Determine which wire is the stop
circuit and attach the module's red stop wire to it with a wire tap (for 3
wire systems only, see step 9).
11.) Route the units green right turn wire to the right side of the
vehicle. Determine which wire is the right turn circuit and attach the green
12.) Install the fuse into fuse holder and test the installation with a
circuit light or trailer.
13.) Secure all loose wiring with cable ties.
Testing Procedure
With the ground wire connected and all of the other circuits attached, attach
the ground lead of a circuit tester to the exposed ground terminal of the 4-flat
end. Activate the tow vehicle left turn, right turn, tail and stop lights one
at a time. Probe the three receptacles of the 4-flat end to confirm proper
functions. If testing with a trailer, make the proper connections and do the
same test as the circuit tester using the trailer lights. If a function on the
trailer lights does not work properly, disconnect the trailer lights, turn
functions on vehicle off and recheck function with the unit with a circuit
tester. Then check the trailer wiring for potential circuit problems.
I hope help you with this (remember rated this help).
Good luck.
