Heating & Cooling Logo
Rod Wilson Posted on Jul 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is my carrier infinity touch control pad z wave capable?
Level 3:
  • Carrier Master 19,187 Answers
  • Posted on Oct 04, 2019
Carrier Master
Level 3:
Answers
19187
Questions
0
Helped
4346261
Points
82261
It does not appear to be. The z-wave has a site that you can check, Neither carrier or z-wave show your model as being compliant. The industry is in a big dispute right now over protocols on home automation standards and it could be worth waiting it out..
2 Related Answers
Anonymous
  • 614 Answers
  • Posted on Jun 04, 2009
SOURCE: The Infinity Comfort Control code
Call your local Carrier dealer. They have code to get into system. Rusty Good system
Anonymous
  • 15 Answers
  • Posted on Jul 08, 2009
SOURCE: carrier infinity control SYSTXCCUID01-B sensor communication erro
There should be a little black sensor bulb outside either on the unit normally under the electrical panel or inside it. It sound like the wire has come off or been disconected. It needs that on to properly run. Your control is trying to communicate with the outdoor unit and can not.
My new carrier infinity system control SYSTXCCITC01-B was working but now has a blank screen. How can I reset it?
I am assuming you have the new Infinity Touch control (black). If the screen is blank, you've either lost low voltage power (an issue at your furnace) or the unit isn't properly seated on the backplate. Pull the thermostat off of the wall and reseat it properly and if this does not work, you'll probably need a pro to come troubleshoot low voltage issues.
Why bose wave radio touch pad does not work ?
There's a setting to turn the touchpad on or off. Yours has probably been turned off. Here's how to turn it on.
1. Press and hold Alarm Setup (Menu) on your remote until -SETUP MENU- appears in the display.
2. Press Tune/MP3 until TOUCH PAD- is displayed (8 presses)
3. Press Time- or Time+ to select OFF or ON
4. Press Alarm Setup (Menu) to exit the menu, or simply wait 10 seconds.
You're done!
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Touch pad keeps racing through temperatures
sounds like you need a new indoor controller. however, you should weigh your options as to what you will do next. if it were my pool, id purchase an Iaqualink board to replace the existing outdoor board. this gives you internet capability, your iphone, ipad, or desktop will now control your pool, and the Iaqualink will control a variable speed pump, for future installations. or, if you just want to fix the problem, buy a new indoor controller.
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Cannot operate touch control pad
Your control pad has gone bad and you will need to replace it... it is easy to replace, just make sure to mark your wires before removing so you can get them back where they belong...
How to Buy Appliance Parts Online
heatman101
Excessive water usage with Carrier LBP humidifier.
hi the water runs down the pad the fan blows air across is , this controled by the stat which should control the water flow / on or off, this should be under warranty in the first year
3helpful
2answers
Carrier infinity control SYSTXCCUID01-B sensor communication erro
Top Carrier Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
