Question about AEG Washing Machines
How to operate an aeg lavamat 506 washing machine
6ya staff
SOURCE:
Anonymous
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
Anonymous
  • 4 Answers
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Posted on Jul 08, 2008
Mukesh Kumar
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
jihadjawish
SOURCE: how do i reset a aeg oko lavamat 72620 washing
how to make reset to AEG OKO lavamat 61600
Posted on Nov 14, 2010
richroth
Richard Roth
  • 9472 Answers
SOURCE: My washing machine AEG lavamat
1) Hold in the Pre-wash & soaking buttons TOGETHER;
2) At the same time, turn the knob clockwise from the OFF position, to "Short Spin". All the LEDS light up.
3) turn the knob anti-clockwise to "energy saving"
4) Machine is reset and the door release clicks.
Switch your machine off and then back on again.
Posted on Jan 17, 2011
Where is the filter for die AEG lavamat 538 washing machine and how do you clean it?
The only filter/screen I am familiar with is the one in the hoses the supply hot and cold water to your machine. They should be checked once in a while but I have never found much in them.
However, the manual for your machine is located here:
AEG OKO LAVAMAT 538 Operating Instructions Manual
Best wishes,
Joe
I’m happy to help further over the phone at https://www.6ya.com/expert/mark_7bbaa7a1174e0903
Aug 24, 2016 | AEG Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
MY aEG OKO-LAVAMAT 610 WASHES BUT DOES NOT EVACUATE.
Check the drain filter, see if the hose is not clogged (blow it), verify proper operation of the pump and the pressure switch if necessary
May 30, 2011 | AEG Lavamat W1050 Front Load Washer
I need the user manual for an AEG Lavamat 1100 washing mashine
How to operate ano AEG LAvamat 1100 washing machine
Apr 13, 2011 | AEG Washing Machines
AEG Lavamat 74800 stops part way through the cycle - Error E50
I suggest trying this link. They will help you online.
https://www.justanswer.com/uk-appliance/23fl9-aeg-lavamat-74800-error-50-reported.html
Oct 28, 2017 | AEG Lavamat 72640 Front Load Washer
I want circuit daigrame for aeg washing machine
I have an AEG öko Lavamat 64600 washing maschine and I need a circuit diagram. Can you help me?
Thanks,
Bridget
Dec 30, 2008 | AEG Lavamat 88840 Front Load Washer
Operating instructions lavamat 538
type in ' AEG lavamat 538 ' into the top right hand address bar on your pc and you will find links that will give you all the instruction manuals you need... AEG is at the lower end of the list....
Good luck
sue
Aug 03, 2008 | Washing Machines
AEG Lavamat 1000
hi
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
sami
Level 1 Expert
Vincent G
Vincent G
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
