The problem has been intermittent for many years, but we found that a periodic hot wash cleared it for a month or so. Recently it is happening every time and we are having to clear the program to stop the buzzing. I have had the covers off and the buzzing is coming from a plastic tank at the back of the main pump. I suspect a solenoid/valve. Is this fault fixable given the age of the machine. Are the parts still available? Many thanks Ian
SOURCE: Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
SOURCE: Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
SOURCE: loud Buzzing noise
Sounds like something may have got past your filter and is touching the main pump impeller eg piece of broken glass or piece of plastic.I,ve even seen a spoon touching the impeller. You may have to take the bottom off the machine and remove the pump if you can,t see anything under the filter,Hope this helps. Regards Stefan.
