Please contact your supplier, they have wiring diagram for 2800 onan generator.
But if you would like to learn more about other kinds of generator, such as diesel generator, gasoline generator, please visit at www.dieselgeneratortech.com.
SOURCE: Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
SOURCE: need a wiring diagram for a bosch alternator
If you ask for a one wire delco alternator,all you have to do is connect the large wire on back of the alternator to the positive battery post on the battery.The alternator is self energizing,there for no problem with wiring up a harness.If I can help,let me know my name is Ron.>>>[email protected]
SOURCE: Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
SOURCE: Need a wiring diagram for a Lincoln Welder
try this page http://content.lincolnelectric.com/pdfs/products/navigator/parts/P72.PDF
if ifs not what you looking for heres the service number for Lincoln
1-216-481-8100
