Electrical Supplies Logo
Anonymous Posted on Feb 15, 2019
In a smps power suply secondery voltage is not steady when disconectin power it comes steady
sherlywang
Level 3:
Master:
  • Electrical S... Master 428 Answers
  • Posted on Nov 30, 2019
sherlywang
Level 3:
Master:
Answers
428
Questions
0
Helped
198581
Points
1063
Starlight diesel generator set faults support article: www.dieselgeneratortech.com, hope it is helpful to you.
5 Related Answers
pravinbhavsa
pravin bhavsar
  • 348 Answers
  • Posted on Nov 21, 2008
SOURCE: PC smps power supply problem
ok you open the pcb check the fuse first then replace it if faulty if it burns again then check 4 diodes then see if 200v big capacitor is expanded or not if so then replace it if not then check diodes after transformer if short then replace it
Anonymous
  • 700 Answers
  • Posted on Oct 28, 2009
SOURCE: Akai 25
try to check its high voltage section for axed HOT or flyback. Also check its regulator. Maybe start up resistor or check the chopper circuit. You should at least have an standby voltage on the secondary side.
Anonymous
  • 4 Answers
  • Posted on Dec 17, 2009
SOURCE: my IBM 15
Manufacturer site under support
have make model info ready
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jun 22, 2010
SOURCE: All voltages are present on power suply board.
Please see my basic troubleshooting guide:
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: try www.shopjimmy.com or Ebay
Anonymous
  • Posted on Jun 17, 2011
SOURCE: i need meter voltage from
in this device the 48 volt(dc) is used for phantom power . and the o/p volt is from the red cable are 36volt,56volt 56volt and 75volt all in dc. take red as ref.
Samsung 29 inch hdtv
Main power supply [SMPS] output voltage is not steady. Contact any service technician. This is not a user repairable fault. Gopakumar Gopalan Google
The power went out and when it came back on the on timer light keeps flashing and I can't turn the tv back on.
the power protector cicuit is enable please check the audio supply and all protector circuit of every secondery voltages
I need meter voltage from power suply. what voltage a suply.
1helpful
Do not start
First remove smps power suply unit box from cpu.
Then ground pin and check is it on you have to ground 4-5 pin blck and green.
Then if it is on then smps is ok.then pull cmos cell from motherbord for 10 minutes make sure cmos cell give voltage.Remove pci cards from pci slot is any.
connect ATX power supply to motherbord then check.
But if smps is not turn on then it has some issue.
Change fuse of smps if still not on then you have repair it or change.
Let me know if you need further assistance.
Thanks.
My t1500 XR keeps clicking on and off when i connect it to the power suply. why is that and how do i solve it?
that is because the power outlet it is plugged into probably doesn't have a steady voltage. which means that if more things are plugged into the outlet then the power could be going from 120 volts to 99 volts to 130 volts and it could be going up and down like that. your ups thinks that when the power goes really low or really high their is a power outage or surge. so it clicks to battery. then when the voltage steadies out it clicks to house current. you will need to configure the ups to have to tolerate that kind of voltage. by plugging the data cord in to your computer it is either a Ethernet to usb or usb to usb, you know a cord that plugs into the ups to the computer to let you configure it.
Have a ATA-100 motherboard, when turning it on it turns itself off within 3 seconds... do not have a manual with this.
Pull cmos cell from motherbord for 10 minutes refix RAM memory .
reconnect all conection to motherbord.
Check your home power supply working fine also check earthnig ground problem.
Some times your smps means your cpu power suply unit has issue.
So try with other smps it is square box on top of the cpu in back side.
1helpful
TV IS DEAD. NO POWER AT ALL. HAD A SERVICE TECH LOOK AT IT. HE SAID THE PCB HAD TO BE REPLACED. IS THIS A COMMON PROBLEM? IF SO , WHY?
If the set is totaly dead then the first place to start is with the SMPS (Switched Mode Power Supply). However sometimes other parts will cause the Power Supply to short out as well. If and when the Power Supply is replaced and the set comes back to life and operated with a Menu then you are probably ok. Note: On your set when replacing the SMPS the tech Must adjust the SMPS voltages to the Panel Voltages. There is a sticker on the Panel that list the voltages the tech must adjust on the SMPS.
1helpful
2answers
3answers
Computer won't turn on
hi
check your power cable , eathing. smps check *********** bord dont touch the cabinet.i think u have motherbord grounding or your power suply of pc has pro.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
