SOURCE: top spray arm came off
more then likely its broken wjhich is why you cant reconnect it. reorder a new one and it will easly screrw back into the top of the dishwasher( pretty common issue)
SOURCE: The spray continually drips
you can replace spray head by unscrewing underneath the sink and bringing to home depot or Loews and match to new one and reassemble
SOURCE: Upper spray arm pops off - all the time
I have had this happen several times over the live of my dishwasher. The problem is that once it snaps off (usually due to a tall item placed on top rack) the tiny teeth in the small ring that fits into the arm don't fit as tightly ever again. The superglue solution sounds like the best I've heard. The first two replacements I ordered worked perfectly, until it snapped off again. The problem now is that the newer replacement parts may not fit the threads of the pipe coming out of the top of the D/W. Good luck finding an original part. If you do, please post here as I will be using superglue and returning the part I just ordered from SearsPartsDirect.com
