Siemans JSJS-217 Wireless Doorbell
SOURCE: bell ringing
the switch that shuts off the dome light and chime is part of the door latch and is broken
SOURCE: the door open bell rings all the time even though
you have a sticking door ajar switch in one of the doors, the only way to isolate it to the problem door is to disconnect them one at a time, start with the drivers door.
SOURCE: The bell that sounds off when you open the door
Oh wow, I bet that drives you insane. The only reason I can think of it doing that is if the door switch located in the lock mechanism has malfunctioned.
Chances are good that you will have to replace the locking mechanism, BUT, sometimes the electrical switch in the mechanism gets dirty and sticks.
This can often be
corrected by performing the following:
1. Thoroughly spray the door switches (on each door) with:
2. Open and close each door several times to work the lube into the mechanism
This is usually sufficient to clean the electrical & plunger mechanism inside the door switch.
If this doesn't work, you could remove the door panel and do the spray treatment from the inside also.
If this doesn't work, the switch may have to come out for repair (see below), or replacement.
Testimonial: "Thanks so much for your help we will do all that you suggested, Thanks so much, Janarie8"
I would try to fix the door a simple weld or used parts at junk yard. rodger.....
