The E5 Error is specific to the TR2000e and the TR3000e treadmills.
The error code triggers when an object is detected by the folding sensors on the underside of the treadmill. The folding sensors look like small trapezoids: two on the back and two on the front. Make sure there are no foreign objects underneath the treadmill. If no objects are present, inspect the sensors for damage. If the problem persists, please contact customer service.
SOURCE: conon mp160 e5 error
Canon printers MP 160 AND MAYBE OTHERS
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
SOURCE: F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
SOURCE: SOLE F80 TREADMILL STARTS TO RUN THEN STOPS.
SimplerFASTERSolution So, I had the same problem. After removing the motor cover I checked everything out per earlier instructions. Everything looked great. Having been a software geek for as long as I've been running (35 years), I as inclined to believe this wasn't a hardware problem at all. It appeared to me that the system just needed to be recalibrated. So...here's what I did. I turned the treadmill on and selected the "Manual" program and hit "Start". The monitor, as usual, counted down 3-2-1. As soon as the rollers started to move I hit the "Slow" button on the right upright several times so I knew that the treadmill was running at it's slowest speed. I then started walking on the belt. I started tapping the "Fast" button and let the belt gradually increase in speed and took it up to 6.0. No problem! But...nobody wants to start each workout that slowly. I had a hunch it was 'fixed'. So, I stopped the treadmill and turned everything off. I started it again, selected "Manual", immediately hit the "2" then he "4" then the "6" on the right hand "Speed" panel, and it ran like new. No service call, no new speed sensor, no fiddling with the little 'diode', etc. Give this a try first...no need to even remove the motor cover. Best of luck!
