Cameras Logo
Genny Patterson Posted on Feb 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pictures are too dark takes pictures at night but too dark to see what it is picking up
Tony Parsons
Level 3:
  • Cameras Master 6,405 Answers
  • Posted on Feb 03, 2019
Tony Parsons
Cameras Master
Level 3:
Answers
6405
Questions
Helped
1652328
Points
20272
Unless you are using flash, night time photos require either a very long exposure, a wide aperture, or a higher ISO rating. If these are not possible with your camera, you will be unable to take photos. Mayhap the instruction manual will give you assistance here.
pacdave
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 104 Answers
  • Posted on Feb 02, 2019
pacdave
Expert
Level 2:
New Friend:
Cheetah:
Answers
104
Questions
0
Helped
34921
Points
318
There's not enough detail to help solve your issue. Can you please post the brand name and model number of the camera?
5 Related Answers
Anonymous
  • Posted on Nov 27, 2007
SOURCE: EVEN WITH A FLASH THE PICTURES ARE DARK
I had the exact same problem and decided that rather than throw it away which would be second.... I took the back off to see if there was anything i could do.
What happened was my cats knocked it over one day and you will see inside there is a battery that is right below the circuits for the two buttoms that control flash and picture. I gave it a little push tighter up to the circuits (they weren't making proper contact) and then after a successful trial shot, put it back together and it is working perfectly. It's amazing to think that a forced movement inside of this device will completely set it off. And I can't even imagine how much money I saved. Knowing full well we don't often get 100% honesty when taking a device in to be fixed. :)
Anonymous
  • Posted on Oct 07, 2008
SOURCE: stealth cam digital game camera not taking night pictures
I have a broke wire on mine can you send me pictures of the inside of yours? my wire is a black wire from the keypad at the bottom of the cam.I can send you pictures of my cam if it will help you
Anonymous
  • 124 Answers
  • Posted on Jul 17, 2009
SOURCE: dark pictures
check out for the ISO settings !!! it wil help u out in taking bright pictures
syed mahmood
  • 77 Answers
  • Posted on Nov 01, 2009
SOURCE: Nikon D40 is taking Dark Pictures. Flash is
kindly see the aparture and speed of xpouser and the iso also if the iso is 100 change the iso to 400 or 800 or u can select he programme option for the best xpousers
Ronald Lockhart
  • 296 Answers
  • Posted on Dec 10, 2011
SOURCE: moultrie D50 game trail camera won't take pictures in dark
Does the flash work? Could be flash circuit or day/night sensor.If you have another D40/D50 camera that flash works but has other problems,swap out the sensors.If not the sensor but the flash circuit then most likely one of the large charge capacitors which has to be soldered in.I use a digital multimeter with I/O capacitor test function..these caps should be about 250mfd.
Takes night pictures but are dark
That may be because (in case you had not noticed) it is dark at night. As you have given us no information regarding the equipment you are using, we cannot be more specific.
Oct 23, 2019 • Cameras
Won't take night pictures
Cameras need light to take pictures.
At night it is dark.
Does that give you a clue ?
Nov 04, 2017 • Cameras
I have a canon powershot SD850. I'm having
Turn the dial to SCN, then use the right/left to select night scene.
Dark photos at night
Before you shoot, try pressing it half-way so the camera can take information how dark it is, then press fully to take the picture. Do this every time you shoot, half-press for a second, then full press to take the picture. If this isn't rectified, check if you have custom ISO settings in the camera, set it to the highest possible value.
May 06, 2009 • Cameras
Pictures to dark at night
no there isn,t.but these cameras do not have enough flash to take great pictures at night,for one you cant be to far away,two you have to have a subject in range of the flash,other wise all you get is darkness.but at the most 10ft is the farthest you can go and still get a great shot at dark.also use auto mode when taking pictures,because it adjusts to light-dark etc.i know this because i have the same camera and its awesome,plus im a photo technician and ran a photo lab for 3years selling digital cameras. good luck,hope i helped
Poor quality pictures
Check your picture settings, the wrong setting for the time of day or object can definetly throw off the appearance of your pictures. Plus, you may have accidentally set it to "warm" instead of auto or black and white, etc. Warm pictures have a reddish tint to them just as the cool have a blue tint. Also I have found the "night setting" only takes really good pictures if you are close to the subject otherwise it is pretty dark!
Dark pictures
You can try adjusting your exposure settings, or try and use the slow shutter speed settings like the auto night mode... Try increasing the white balance as well...
Cannot take pictures
cannot take a picture the lcd is on blank screen
3answers
INDOOR PICTURES ARE TOO DARK
try using the night shot it will go slower but it works well for dark pleases
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
