Hi, my wife and I purchased the Health master blender about 6yrs ago. I recently noticed that the liquid was leaking from the bottom of the container. The blade is totally loose. How can I tighten it if at al?
I'm no expert but in my experience if it leaking at the bottom then either the jar /carafe has a few chips or cracks around the hole in the bottom that the blade fits through and in that case you need to replace the jar and your blade assembly may still be good and can be moved to a new jar/carafe. Or the blade assembly has come loose a little and need to be tightened or some the washers (usually the rubber ones) have worn out and need to be replaced. There's plenty of explanation here at amazon and else where on how to replace the assembly blade, move it to a new jar and tighten it down, etc. Hope this helps!
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
I have the same blender and it's had a slow leak all the way up until today... when all of the fluid ran out of the bottom of the pitcher and all the lights on my blender started flashing. I've tried tightening the blade, but it doesn't seem to tighten... I think I'm going to have to call KitchenAid
Mine also leaked from day 1. I just read in the manual to first place the bottom and blade assembly on the counter, then seat the gasket around the blade assembly, making sure it is just under the lip of the blade piece (careful, you have to maneuver around the blades). Then place the jar on the assembly and screw in tightly. This worked and I have no more leaks. This is different than other blenders where you place the gasket on the jar and then attach the bottom. It is a poor design, but after what I paid for it, I am glad to be able to use it and not just trash it.
I just figured it out. The key is you need to think in terms of keeping the blades and the large washers separate. Here's what you do.
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Exact same problem. Turned out the threaded shaft that holds the blades was broken so tightening the nut on the top doesn't really help. Just ordered a new blade assembly from www.smallappliance.com. Mine was the Waring 007314W Blender Cutting Assembly but there is also an older one for earlier models. Don't know if it will work yet (assume it will), but cheaper than buying a new blender.
