SOURCE: where to buy face plate at bottom of 1990 corolla shifter
Some Auto Supply stores like Napa carry this and the Dealership Parts Counter has them Also.
SOURCE: 1998 Chevrolet Cavalier rotors and or drums?
For car parts autozone and autopartwarehose are best car parts site.
But for this brake problem,i suggest you to click this link below and follow the troubleshooting procedure and confirm the issue.Click the link below :----http://technoanswers.blogspot.in/2012/02/squeak-and-grinding-sound-is-heard-when.html
----------This will help.Thanks.
Testimonial: "Thank you for the very useful link :)"
SOURCE: how do I change a wheel on a piece of rollon luggage?
if you have a rivet gun you might be able to change it out (pry the old rivets out and attach the new wheel). Remember though that handyman guns are lightweight and the new rivets will probably not be as strong as the originals.
Checks
Cause
Case (7)
The rear band anchor pin is broken or the pin is not positioned.
Center Support (640)
Leaking at the case, or the support is broken.
Center Support Seal (639)
Leaking
Center Support Bolt (25)
The bolt is loose or broken.
The feed hole is blocked.
Rear Band (657)
Broken, worn, or not anchored
Rear Band Apply Pin (73)
The pin is too short or the pin is binding in the case.
Piston (65)
Binding in the case
Seal (66)
Leaking, damaged, or worn
Gasket (63)
Damaged or displaced
Cover (62)
Damaged
Bolts (61)
Broken, loose, or missing
Checkball
Missing
Fluid Pressure
Too low
Direct Clutch Components
Reaction Plates (618)
The splines are worn.
Friction Plates (611)
The splines or the friction are worn.
Spring Assembly (607)
Jammed
Housing (623)
Cracked
Piston (619)
Leaking
Seal (620, 621, 622)
Leaking
Ball Check
Leaking
I'd purchase a new one
If your luggage, specifically the bottom plate supporting the wheels, is damaged and you want to repair it yourself, you have several options. You can contact the manufacturer for replacement parts, search for spare parts online, visit a luggage repair shop, or attempt a DIY repair. Additionally, family guest house in karachi consider warranty coverage or travel insurance if the damage occurred during travel. The best choice depends on your luggage's condition and your preferences for repair.
