I suggest you contact your supplier or local maintenance person.
If you plan to purchase diesel generator set in future, please contact [email protected]
SOURCE: 1990 Toyota Pickup
carb or Fuel injected try cleaning either one of these bad distributor cap or rotor or distributor good luck
SOURCE: 03 chevy avalanche, no oil
Almost feel bad answering this one but if you have low oil pressure (verified by an external mechanical test gauge, not the one on your dashboard) Likely you replaced the oil pump but did not check the bearings on the crankshaft for wear. It is highly unusual for an oil pump to fail. Most often low pressure is caused by bearing wear. A pump can be damaged by ingesting debris from a failing bearing and should be changed, but only after the bearings have been replaced, otherwise you are fixing the result, not the cause of the problem.
Testimonial: "190k on the motor, I hope I don't need a new one already."
SOURCE: My car is racing and
It sounds like it may be your Idle Air Control Valve. This is a common maintenance item on many Ford/Lincoln models. It controls the idle speed for the fuel injection system and when it goes bad it will act just like what you are describing.
