Tablets & eReaders Logo
V
Virginia Trostle Posted on Nov 07, 2018
My iPad keeps coming up with Google play services and you have to tell it ok to clear screen but how can I fix the problem?
  • Ray Nov 13, 2018
    Hi Virginia Trostle, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the message saying exactly?
3 Related Answers
VERTIGO
  • 34 Answers
  • Posted on Jan 12, 2015
SOURCE: How do I recover Google apps and play store to my Samsung galaxy tablet 2, after factory reset,
Go and search it on the Play Store and manually install it.
If it fails try searching on google for an apk of google services and install it on your device.
Harrie
  • 6746 Answers
  • Posted on Apr 15, 2015
SOURCE: Download google play store app to iPad iOS 4.3.5 so I can get google lat store app
Even when you manage to put the Google play store app on your iPad, you won't be able to run any of the apps they sell there. You need an android tablet to run these apps.
Terry Corrow
johnny rebel
  • 10875 Answers
  • Posted on Jul 08, 2015
SOURCE: I get pop-ups on my LG OPTIMUS ZONE2 saying "google acct.man.google services framework,google play services,com.google.process.gapps has stopped. How do I fix these problems?
delete google,d/l google and then update google
My lenovo tablet won't let me open setting because I get message saying unfortunately google play has stopped working, does any one how to fix this problem? Can any one help
Google Play Services, the preinstalled app on your phone plays an extremely crucial role in the regular running of your lenvono. If anything is wrong with it, then your lenovo will start throwing fits in the form of errors and crashes including 'Google Play Services keeps stopping' error.
To remove the error, you need to fix Play Services. Here you will find numerous ways to fix any issue related to Play Services. Let's get to know them.
1 Starting with, will actually with restarting you Lenovo.
2 Another that does wonders for any issue is to "clear the cache" and date of the particular app. In this case, we need to clear cache and data for "Google Play Services" and "Google Play Store".
Doing any of that will not delete any data from your phone. However, clearing data will log you out from Play Store and reset its settings. In settings
3 "Google Play Services" is a system app, you cannot remove it from your lenovo completely. However, you can uninstall the updates, which will revert it to the factory version forcing your phone to update it automatically, thus fixing any issue.
On the Google Play Services screen, tap on the "three-dot" icon at the top-right corner. Select Uninstall updates from the menu.
4 Unlike other installed apps, you don't have to update Google Play Services manually. It's done automatically in the background by your lenovo.
However, sometimes, the issue is with the update itself. So you need to update it to the newer or older version manually. We have covered ots of ways to update google play service in detail. Do check that. And if you face any issue while updating it, check fixes.
6 Similar to restart, sometimes booting in the safe mode fixes various issues on an Android phone. Again, doing that will not delete you data and you can access it in safe mode as well. Running the lenovo in safe mode also helps in identifying the issues caused by the third-party apps.
I hope these will get you over your issue with ease.
How do I keep videos from playing on lock screen of iPad Air? I do not want videos to play on lock screen.
Probably under your settings somewhere on your iPad or email account settings. Depends on where the videos are coming from.
1helpful
I keep getting unfortunately the google search has stopped. and nothing works
This happens on the Android system including all Google services
Google search,Youtube,Play Store ...
To fix this problem :
go to Settings
- Application manger
- Google Play services
then Clear Cache .
that's it
Nov 30, 2015 • Nabi 2
1helpful
The Google play services are not working on my Tablet, how can I fix this?
Google Play Services needs to be updated from time to time. It seems to keep getting bigger and bigger. You can go into Settings - Apps and then ALL and scroll to find Google Play Services and then click on it. The screen that comes up will give you the option to clear the cache and clear the data.
First clear the cache. Then see if that solves the problem. Likely it won't. Then you can clear the data. It that doesn't work for you then click on *uninstall updates.* This will reset the Google Play Services to original factory. Reboot and make sure you have a good wi-fi connection as the Google Play Services should connect to the Google Play Store and update automatically. If it doesn't, then open the Store app and select *My Apps* *All* and scroll to Google Play Services.and click *Update*.
Note: the Store App, itself, might be slow and balky until the updated Play Services is installed and running.
Here's a hint. If you do the above and delete the updates from the Google Play Services app on your device, when you boot up your device might act balky - just give it a few minutes as it's probably connecting and downloading the Google Play Services updates automatically. Google Play Services is important for just about everything that communicates with Google so don't expect all the other Google apps to work until the updated version of Google Play Services is installed and working.
2helpful
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
