Electrical Supplies Logo
Anonymous Posted on Oct 21, 2018
I want to install a decora switch with a non-decora dimmer as a three way switch. Will this work?
Will the wifi enabled switching still work? (Does the decora "know" that the light is off even if it did not turn it off? Does the fact that the other switch is a dimmer mess with this?) Or do I need to install both switches/dimmers in the three way switch as decora so they can sync with each other?
  • J Rosado Oct 23, 2018
    They make those combinations. Look for a Decora / toggle switch combination finish plate.https://www.google.com/search?ei=RB_PW6r...
CJ Rock
Level 3:
  • Electrical S... Master 4,429 Answers
  • Posted on Dec 20, 2019
CJ Rock
Level 3:
Answers
4429
Questions
0
Helped
1645575
Points
15024
The smart switch may interpret an extreme low dimmer setting as circuit off state
The actual switching (traveler swap) would likely function but the load on/off state may not be properly reported back to the controller.
So if you were to query the state of circuit remotely it may show off state when actually on. You command on, the travelers flip, so now actual state is off and smart switch reports off. You command on, travelers flip, circuit is on but smart switch reports off.
The standard 3 and/or 4 way switches can remain but suggest you use the Decora smart w/ dimmer in place of the standard switch/dimmer.
J Rosado
Level 3:
  • Master 1,202 Answers
J Rosado
Master
Level 3:
Answers
1202
Questions
Helped
500674
Points
3432
Get a 3-way smart switch in your system
5 Related Answers
VtToolMan
Mark
  • 704 Answers
  • Posted on Aug 07, 2009
SOURCE: Problem w/new sliding dimmer
The problem is that the Cooper #9530DS-K-L is actually a 3-way switch and you need a single pole dimmer switch to replace your existing single pole toggle switch.
If you want to use the Cooper switch you have you can take one of the black wires and cap it with a wire nut and connect the other two wires, but frankly, you'd be paying about 2 times the price for a 3-way dimmer switch when you only need a single pole switch.
You should be able to return the switch and get the correct one.
You should only have (2) black wires on the proper replacement switch, plus a ground wire
Hope you found this very helpful and best regards!
Hippy_dd
  • 112 Answers
  • Posted on Aug 21, 2009
SOURCE: touch dimmer malfunction
sounds like a loose connection to me, check to make sure all connections are tight. sometimes the bulbs themselves don't make a good connection in there socket.
u will have to take the switches out of the wall box and make sure the wires are tight, whether they are on screws or wires connected to wires. if it is wires to wires u may have to take that apart to make sure u don't have a bad connection there.
if it is none of that, then it is time to replace the switches
VtToolMan
Mark
  • 704 Answers
  • Posted on Nov 17, 2009
SOURCE: I'm attempting to wire a 3 way switch with a dimmer
Hello Chris,
What has happened, is that you've got th two "traavelers" reversed on the plain toggle switch. These are the RED and BLACK wires. turn off the power and reverse the position of these wires and the switch should work correctly from either the Dimmer switch or the plain switch.
Here's a link with a diagram, which might not exactly match your circuit configuration, but you can also watch a short video that explains how 3-way switches work.
It is just a matter of getting the travelers on the correct screws in order for the circuit to operate properly from either switch. Also, depending on the type of dimmer you've installed, the other switch will only turn the lights on at the dimmer setting that you've left the dimmer switch in. So be sure that you're not turning the dimmer all the way down before you shut it off (at the dimmer) otherwise, the other 3-way switch won't be able to turn the lights on, regardless of whether you've got the travelers in the correct locations.
Remember to turn the power off to the circuit you're working on while you rewire it and flip the breaker back on when you're done.
http://www.electrical-online.com/3waydiagram.htm
Hope you find this Very Helpful and best regards!
Anonymous
  • 843 Answers
  • Posted on Mar 17, 2011
SOURCE: Looking for a wiring diagram
I know you asked for a diagram, but this may solve your issue. If both switches are 3 way (not 4 way) then they will have a single terminal on one side and two terminals on the other. The two terminals on both switches are for the "traveler" wires. Your first switch will take power in (the black wire) to the single terminal. Two traveler wires connect the two terminals on the first switch to the two terminals on the second switch. The single terminal on the second switch is the output to the light. In addition there will be a ground and a neutral coming in to the first switch box, and just passing through to the second box, and just passing through to the light. So, in total, here are the wires---- The input to the first box should be a black (hot) , white (neutral) , and bare (ground). Between the two boxes will be two travelers (usually a black and a red), the neutral (usually white), and the ground. Out of the second box will be the same as the input to the first box. I hope this helps. By the way, as long as there is only one dimmer, it's the same as no dimmer. And if you have four terminals (and therefore 4 way switches) you can just tape over (and don't use) any one of them and you have a three way Good luck Al K
Anonymous
  • 107 Answers
  • Posted on Sep 12, 2011
SOURCE: I am replacing a Lightolier
It depends. Some dimmers are considered "smart dimmers," where the control on the other end of the 3-way has to be intelligent enough to send a signal back to the dimmer. If the Lightolier dimmer was a smart dimmer, then chances are that the 3-way control was designed to talk only to that specific dimmer. The Leviton product you replaced it with is a simple, basic dimmer - it should work in conjunction with a simple, basic 3-way switch.
If the 3-way control already IS a simple, basic 3-way switch - then I would simply re-check the wiring of the dimmer you replaced.
1helpful
Installed 2nd switch it does not work
If you are talking about A THREE WAY SWITCH, they can be a little confusing for a beginner.
here is a link to some drawings that might help.. IF YOU ARE NOT TALKING ABOUT A THREE WAY SWITCH, give me a little more information. 3 Way Switch Wiring Diagram
When I turn the light on it doesn't dim at all, and when the dimmer is at full power it flickers non stop. What is the solution?
Switch the hot wire and the wire going to the light around... you are wired basackwards...
heatman101
2answers
Is it possible to dim a three way switched light circuit
Here is an article that will answer you question very thoroughly...
http://www.ezdiyelectricity.com/?p=441
heatman101
1helpful
2answers
I have a bad decora switch, how can i tell if it i...
In addition to your answer that was given to you. Look at the amp rating on the switch you just removed. It's probably a 20 amp switch (if you already had 12 guage wire in there, and it worked fine), and you're replacing it with a 15 amp. Happens all the time. As far as the answer given you, its fine. The only time you would use a 4-way switch is when it's being operated by two 3-way switches from opposite ends like the gentleman mentioned. I would suggest getting the correct 3-way switch. It just makes things easier. And again, turn OFF the circuit when working on this switch - or anytime you're working on anything electrical. This is a huge Rule-of-Thumb! I've been doing electrical work for over 27 yrs., and I always turn OFF the electricity.  Best of Luck to you, and I hope this is a little added solution to the one you already have. Take care...Jim
2helpful
I have two Leviton Decora Motion Activated Light Controls model PR180-1LA that I would like to use at the top and bottom of a stairway. There is only one light that needs to be turned on and off by the...
Unfortunately you cannot use two PR180-1LA's for what you want to do. :-( There is only one correct installation:
One PR180-1LA needs to be installed at the switch box which contains the cable that goes to the light (load). That is a must. One then installs a regular 3-way switch at the switch box which contains the cable with the hot from the breaker (line or source).
If you reverse the sensor location you will need 4 wires between the switches, which is not usual practice, as the bare grounding wire is not permitted to carry current per National Electric Code rules.
If you want a sensor at both locations you need to install a IPP15-1L at the switch box that has the cable going to the light (load). One must then install a IPP0R-1L at the switch box that has the cable with hot from the breaker (line or source).
Wiring ceiling fan to a light/fan dimmer swich
I think you should get a licensed electrician , if you dont wire it up correctly you could burn your house down and i dont think insurance companys take klndly to diy electrical work around the home .
Leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
