Electrical Supplies Logo
Alan Herosian Posted on Oct 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I call for help on sump pump warranty .....mine did not work for the NC hurricanes this month
sherlywang
Level 3:
Master:
  • Electrical S... Master 428 Answers
  • Posted on Jan 06, 2020
sherlywang
Level 3:
Master:
Answers
428
Questions
0
Helped
198588
Points
1063
Ask your supplier who supply the pump to you, maybe their engineer can tell you.
Replacing Zoeller switch after water got in the case?
I imagine you asked the plumber why the pump is running continuously and he replied as you said but what he simply meant was, because water is in the sump. I'll address pump switch failure later.
So the question should be why is water continually entering the sump. It could be because the water table level is high but its been my experience a sump pump runs nonstop because water expelled by the pump is flowing directly back into the sump.
Have you asked neighbors if their pumps run nonstop? Do you have continuous standing water around your home?
If you don't have standing water around your home and your neighbors dont have the problem with their sump pumps running nonstop then the most likely cause is the pump outlet is flowing back into the sump. In other words, its continuously recirculating the same water.
Here's how I"ve diagnosed this issue in the past. Install a temporary 1 1/2 inch pvc line to discharge the pump outlet on the ground a minimum 20 feet from the house foundation on ground with a downward slope. This gets the pump outlet far enough away from the house that water should not re-enter the house sump. If your pump then cycles normally, you know the problem is because water from the pump outlet is reentering the sump. Then it's a matter of determining why the original pump outlet is flowing back into the sump.
As for pump failures... most sump pumps are not designed for continous duty and the switches are of marginal quality. I alleviated the switch issue by zip tying the switch float of the pump up so it is always on and installed a seperate sump float switch that will last longer than the original.
I have straight talk home phone in Clarkton nc service not working since 9/24 what is going on?
If you're in North Carolina service is probably interrupted by the hurricane.
Contact Straight Talk customer service to verify:
1-877-430-2355
Sep 26, 2018 • Cell Phones
I have a 12 volt emergency sump pump system SD-BSP. Sensor float failure.
If it is anything like mine the sensor is on a cord So what I do
is get some plastic wire ties and tie the cord part lower on the pump
so the float part does not have to move so far. cheap fix
oh BTW if you cannot secure it to the pump then maybe you have some vertical part you can secure it to .
GL
edward edwardaustinassociates
1helpful
3answers
Won't stay runing when I twist the throttle
i own an 87 myself and excellent bike...i had a similar problem but it didnt die right away it just bogged down...it was the fuel pump! i looked in my manual and dont see anything that would cause this particular problem, but im thinking that the throttle is attached to the starter and kill switch assembly....maybe something is shorting out in there?
2answers
Sump pump drain
Storm sewer or rain water run off area. In other words , almost anywhere where it won't come back in.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
