Check with the airline whether you can take the battery and if so whether it can be hand luggage or must be stored in the hold. Wise also to check whether US Customs is likely to have any objections.
Battery capacity or performance isn't usually measured in watt hours, it is more usual to rate a battery in amp hours (AH) measured at either a 10 or 20 hour rate - a battery that will supply 1 amp for 10 hours is rated as having a capacity of 10 AH and a battery capable of supplying 500ma for 20 hours will also have a rating of 10 AH.
SOURCE: CAMERA WILL NOT DOWNLOAD IMAGES TO MY COMPUTER
Xray machines do not effect memory cards, or cameras, according to the experts. The first step to figure out here, is whether the memory card, or camera is at fault. If you have a card reader, or a printer with card reader slots, try to download your pictures that way, bypassing your camera. If you still can't download them, try another memory card in the camera, and see if that one works. If it does, we can assume the memory card is bad, however, they rarely go bad- they might get dirty contacts, but they're pretty sturdy. If the camera still isn't working after trying the other card, there is a problem with the camera. There are a few ribbon connectors in the camera that can come slightly loose with vibration or shock, and it's possible that this has happened. You can reseat the connectors, but you have to disassemble the camera to do that. There are videos on YouTube that show how to do this, in general, if you elect to do that. Otherwise, at this point, you will have to have the camera serviced. Make sure you get an estimate first, since the cost of repair can be fairly high, often justifying the purchase of a new one. Good luck, hope this helps.
SOURCE: I brought TV(Sony Bravia) from
250 watts would be enough - the tv's maximum is about 220 watts.
SOURCE: The sound is no longer
If not a separate PCI card connected on the motherboard it should be integrated to the board and the outside port is a 3.5mm green circular hole which usually is located near (if not above then below) the ethernet port.
First off check the BIOS if the integrated devices are enabled if there's no option they automatically are.
Second boot into the operating system and make sure that the driver is installed if not then the driver is available for download at the DELL SUPPORT SITE. (try reinstalling the drivers).
Try another set of speakers just to rule the speaker out as the problem. Then check the configuration make sure that the sounds is not muted from your computer.
Hope this helps!
You cannot precheck luggage... it must be weighed and or inspected....
SOURCE: if i purchase 20kg check in luggage is it valid for return flight too
Check your particular carrier. Rules vary among carriers.
My question is regarding Saregama Carvaan
