Electrical Supplies Logo
S
Steve likens Posted on Sep 24, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is low voltage diagram for x16k464457 Stamford. 60kw 3phase
sherlywang
Level 3:
Master:
  • Electrical S... Master 428 Answers
  • Posted on Dec 07, 2019
sherlywang
Level 3:
Master:
Answers
428
Questions
0
Helped
198537
Points
1063
Diesel generator set with Stamford alternator. If you are interested, please visit at https://starlightgenerator.en.made-in-china.com
1 Related Answer
Anonymous
  • 767 Answers
  • Posted on Jan 12, 2010
SOURCE: York 3phase compressor tripping on low currant microprocessor.
If the unit is single phasing this is not good for the compressor. Does the system have a phase monitor? If not I would suggest you put one in to save thousands of dollars on the replacement of the compressor. How is the oil level? I ask because this are not to run themselves out of oil.
Why 3phase 400v motor the supply is 230v also the is capacitor inside 3phase motor , what is the use of th capacitor in that 3phase motor
there is no capacitor in 3 phase motors. if you are trying to tun 480 motor on 240 or 208 there is a wiring plate on motor, perhaps you should not attempt this., you do know that the amperage will increase if you run lower voltage.
How to check exciter and need to feed point the portion of avr
What alternator does your model have? Marathon? Stamford Newage? You can download a generic service manual for Stamford here, http://www.advanced-power-technologies.com/mydocuments/fault_finding_manual_8.pdf It is basically the same. If you found the manual useful please leave Facebook feedback https://www.facebook.com/pages/Advanced-Power-Technologies-LLC/1446298015596760
Sorry bought magnum compressor 3phase but also runs 240v cannot get it to run on 240v any info would be realy helpfull ta Peter
if you have a 3phase motor it will only run using 3 phase power no matter what voltage or you can get a phase converter but they are pricey and varies with what horsepower your motor is
1helpful
2answers
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
1helpful
Do i use 10-3 withground?Im hooking a 18000 BtU Ac heater
A normal 2phase 220 or 240 V unit usually requires
2 wires and a ground. If you know what a contactor
is you will notice that only two line voltage wires can
be inserted into it and the ground wire to the equipment ground.
If you have a 3phase unit you would need 3 wires and a ground. Usually on the back cover of the unit it will
show the wiring diagram
I need a diagram to change a hawkersidley stamford 25kva generator from 240v to 415v
There should be a diagram inside on the wall of the unit where the jumper bars are, where you change voltage connections.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
21helpful
2answers
Converting from three phase to single phase
I have 3phase blue seal electric fryer how can it be converted to single phase please? i have been toild it can and it will take 45amp fuse. please advice.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
