Electrical Supplies Logo
A
Anonymous Posted on Sep 17, 2018
How do I find an owners manuel for Model number Powermate PMO 143400 portable generator? Or one identical sold by Walmart Model Powermate Wx3400?
sherlywang
Level 3:
Master:
  • Electrical S... Master 428 Answers
  • Posted on Dec 07, 2019
sherlywang
Level 3:
Master:
Answers
428
Questions
0
Helped
198404
Points
1063
If you plan to have a new portable diesel generator set in future, please visit at https://starlightgenerator.en.made-in-china.com
5 Related Answers
Anonymous
  • 169 Answers
  • Posted on Mar 01, 2009
SOURCE: owners manual
Yes there is, here.
Regards,
Carl
Anonymous
  • 1865 Answers
  • Posted on May 18, 2009
SOURCE: Owners Manuel for Kenmore Deep freezer
This link will take you to your owner's manual. You can save it as a pdf file
http://www.managemyhome.com/mmh/owner_manuals/search?query=253.9280412
protek480
Craig Butler
  • 1730 Answers
  • Posted on Aug 01, 2009
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Anonymous
  • 4088 Answers
  • Posted on Sep 26, 2009
SOURCE: troy bilt gas portable generator not producing
First thing to check is to see if the generator is actually turning--couplers sometimes fail. You need some electrical skills and a voltmeter to trace down problems in the generator beyond checking the health of the two brushes that supply current (< 115 volts DC) into the rotor field circuit. You can find wiring and schematic drawings on the Troy-Built web site, just look for the 030248 model. Another person that I worked with had a similar unit with the same problem. It looked like the voltage regulator board was the problem, but haven't heard back if he had fixed it.
Anonymous
  • 3 Answers
  • Posted on Oct 13, 2009
Try this link. The model number will be on your endbell.
http://www.powermate.com/productmanuals.php?cat_id=3
I am looking for an owners manual for a Coleman gasoline powered 120/220 generator
Coleman is now Powermate.
https://www.powermate.com/generators/portable-generators
Post model number and likely someone will comment with a URL address of the manual.
DO YOU KNOW WHERE I CAN FIND AN OWNERS MANUEL FOR A COLEMAN POWERMATE DIGITAL COMPRESSOR, 12GALLON175PSI, STAGE 1, MODEL#VLA1681209?
Try doing a Google search using the make and model number. Also, these show up on Ebay some times.
Pmo 0544655
Take the through bolt out of the end of the alternator / rotor shaft. it is a long bolt. The shaft from the engine is tapered and unlikely to just pop off. Find a bolt that will screw into the end of the rotor shaft (hardend) find a metal bar that will slide into the rotor long enough so the bolt tightens down on the bar, it will pop the alternator off the tapered shaft
Powermate 5000er 10 hp won't start no fire to the plug
Make sure that the generator is full of oil. It has a low oil level sensor that will ground the spark if the oil is low. If you have filled it to FULL with oil and still have the problem disconnect the low oil level sensor (one wire) and check for spark again. IF you now have spark the oil level sensor has either failed or is dirty. (yes you can clean them with carb cleaner.)
If after doing the above you still have no spark... I need 2 things.
1. the actual model number off of the generator Will start with PM or PMO
2. the engine model number / type / series number off of the engine
Thanks for choosing FixYa,
Kelly
5helpful
How can I get a owners/instruction Manual for my Coleman Powermate 5000 Model PM0545305.03
follow this link to get the user manual guide as per your model no:
http://arkansas-ope.com/COLEMAN_GENERATORS.html
Need to know about this generator. Coleman Powermate 6250 Gen power 305 5000 running watts Model PM0545008 Serial # E06601199B
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
2answers
Coleman generator model PMC525501
Try this page http://www.arkansas-ope.com/COLEMAN_POWERMATE_GENERATOR_IPLS_LISTING.html.
i know powermate company went out of business, think they sold out . see if this will help. go to the bottom of web site page if you cant open your part number. let me knoww if this helps. thanks, troy
Top Electrical Supplies Experts
john h
CJ Rock
CJ Rock
Are you an Electrical Supply Expert? Answer questions, earn points and help others
