If you plan to purchase diesel generator set in future, please visit at the website for your reference:https://starlightgenerator.en.made-in-china.com
SOURCE: Replacing engine on Powermate 5000W Generator
I would say, yes (given everything bolts up okay), but I wouldn't connect a full 5000-watt load to it.
SOURCE: John Deere Generator _Manuals Model HRG 1100
First of all, thank you very much for choosing FIXYA today for your technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.deere.com/en_US/parts/media/pdf/homeandworkshop/manuals/hr-g1100.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
SOURCE: No electric power generated from my Coleman Powermate Maxa 5000W.
I had the same problem and found that the terminal that connects the circuit board(containing the brushes) to the stator, had bad or blown out solder joints after the generator had been run under a very heavy load.resoldered and problem has not resurfaced.good as new.hope this helps..
SOURCE: Operators Manual
You can get a manual from this WEB site.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/ryi2000t.html
as most carbies are generic in nature ( made by a small number of manufacturers ) talk with a mower shop as to parts availability
if you can get a name of the carby and if possible a number , you could get complete new carbies from e-bay
If I remember rightly this would not run when the choke was put off
if that is correct , there is a problem of a blocked main jet or insufficient fuel flow to the carby
the fuel tap is probably metal and if so , they corrode up inside and block the flow
comment as posts are not linked and the answer thread is lost
