SOURCE: my father bought a new charger from a battery
hi,
The battery connections are normally positive 24, Negative 24 & inhibit which is normally grounded, for some scooters the charger connections go to the batteries plus the controller but that does not mean it been zapped, hopefully there is a fuse (Car type ?) under where the seat seat stem is , a simple test is to turn it on, does the horn work ? does it appear to power up ?
Some scooters have a fuse in the tiller panel or control panel as it otherwise known so check it out and hopefull it will work.
Regards
GeWiz.
SOURCE: Would this work or burn
This should work just fine as long as the breaker it is going to is at least 20 amps as this is the amount of amps that both fans would be drawing at once if the were both on. The 12/2 wire should be plenty to supply the 20 amps needed for the fans.
Yes everything would work perfectly. I see no problems in your plan. Even if both fans were run off of one switch they would not burn out, the circuit it appropriately sized. You could even go a step down to save yourself some money and use 14/2 and 14/3 (supposing its only the fans running on the circuit). You can run up to 16 amps on 12 AWG wire and up to 12 amps on 14 AWG wire (80% of breaker tolerance). Also when it get to the fans use a wire junction box run your 3 wire cable in there and branch out to your fans from there with separate 2 wire cables. I believe that was your plan just wanted to clarify. Good luck!!
SOURCE: i just bought a switch
The key seems to be that you changed wiring in the ceiling box.
I suggest you make a drawing of the wires before and after. Track the route that the Hot wire takes.
The key question is this: Does Hot wire from breaker box arrive in the ceiling box first? Or does it arrive in wall box first?
I think Hot from breaker arrives in wall box first. And from there Hot wire goes to ceiling box ... and from ceiling box the hot wire goes to other plugs in room. If this is true, you will be one wire short for installing fan control switch.
I always make a drawing of existing wires before starting, so I can put it back the way it was. It sounds like you got a good handle on which wire goes where.
We used to solve the one-wire-short problem by making a simple project bigger. Figure out which direction ceiling joist run. See if you can slide fish line from fan ceiling box over to wall. If that works. Over at the wall, chop small hole in ceiling so you can feed wire up to fish line. Pull wire over to ceiling box. Next, staple other end of wire along ceiling over to location above wall box. Chop another small hole so you can feed wire down to wall box. And then install beautiful crown molding to hide the mess, and paint the room so you need new furniture.
SOURCE: I have an electric box
You have a combo light switch and GFCI.
It sounds like you are 1 wire short.
Where is the wire that goes to the light?
The black wire should be Hot, the white wire could be the Neutral or the could be the wire going to light.
The Black hot wire connects to dark-colored or brass screw on one side of device. This screw should be labeled Line.
You need a white Neutral line that connects on silver-colored screw that is located opposite where black wire connected.
The switch controls a light ... but you need another wire going to the switch.
Add a comment. Post a photo on Imgur.com and add that to your comment.
Hi james hildebrand, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? A photo would be very helpful
