https://www.dieselgeneratortech.com/generator-sets/Information-of-Starting-Battery-in-Diesel-Generator-Set.html
SOURCE: Looking for an ONAN Emerald I GenSet generator manual
I have an account in the Buffalo NY area .. they can help you with this .. call 716-668-2666 after 9:00am EST tomorrow (sat)
SOURCE: onan genset generator in rv is running but no
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
SOURCE: Onan Marquis Indiana 5000 generator
You MAY have blown the rotating diodes on the rotor.
This would require servicing.
SOURCE: I have a Onan 7000 genset in my rv It starts and
Either you have a kill wire ( if I remember it is the brown wire) that is disconnected on one end or the other Or your in coach switch is bad.
Check the switch this way
Remove the switch from the dash/ mounting surface unplug the brown wire - start the genset - ground the brown wire - it should kill the motor
If it kills the motor your switch is bad
SOURCE: RV Onan Emerald 1 Generator
Check all the ground wires and make sure their not broken or loose. If the wires are good next check the neg. Wire to the coil. Too check the swiitch make sure you have continuity too all the post when the switch in the on position, this requires removing the switch.
