Onto my computer with a USB adapter for sd cards, my computer knows theres a usb in but says theres no pictures on the card when I put it back in my camera all the pictures are there
SOURCE: lost my usb cable
Your camera manual will tell if transfer from internal memory to card is possible.Some do some do not. Another USB cord should not be very expensive
SOURCE: SONY DCS T1 FORMAT ERROR C:13:01
Hi.. I think you have solved the problem yourself... replace the adapter with a memory stick... You have eliminated the micro sd card as bad... now try a new known good memory stick..
Thanks
jim
SOURCE: need pictures off memory card
More than likely this is not a memory stick problem, but a computer problem. Have you used this port before for other uses? sometime a port will get sloppy( for lack of a better word) and you may have to tilt or hold the card with your hand, so that the computer will pick it up. Try that.
Hooe it helps.
SOURCE: cannot copy photos from internal memory to SD Card
Put your card in and scroll down. Even when it looks like you're at the bottom scroll more. You'll see copy. Go to the pic that says in with an arrow to an sdcard. select and there you go. It took me ages to find it but it's there.
SOURCE: i have pictures on the memory stick pro duo 2GB
Once it was happened to me, I went in folder options, enabled 'show hidden folder and files' option and got all pictures in memory stick that were hidden in picture folder for some reason. Selected all with CTRL+A, right clicked, clicked propertise and uncheck hidden mark
Try that, might help you.
