The lights are on&the other buttons work but the wash cycle won't turn on
SOURCE: Kenmore Elite HE3 front loading washer
Before you go crazy trying to solve the F2 code make sure the filter is clear. Disconnect the power cord, PLEASE. Remove the kick plate on the bottom front by removing the 3 screws below it. You will need a hex socket and extension or a torx screw driver. If there is water in the machine and it will not drain you will need a shop vac and some old towels to catch the water when you open the filter. Now, you will see the filter in front of you. Have the towels ready and vac turned on. Quickly unscrew the filter cap and stick the vac hose right in the filter to catch the water. Clean the filter cap. Did you find any socks, money or other debree ? If yes that may have been your problem. Put the filter back on and HAND tighten well. Test the machine. From now on empty all pockets before you do the laundry. You just saved yourself a big repair charge. Be proud of yourself.
SOURCE: Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
SOURCE: Problem starting fridgidaire model FDB1050REC2
hello kwill8
welcome to Fixya.
You said, You just installed the dishwasher and the only cycle it will go through
is the rinse cycle. When You turn the dial to any of the other cycles:pots&pans, normal, light wash and upper rack, the start button
as well as the heat dry button and the high temp button do not work.
only button that will light up when pressed is the delay button. How
can you fix this?
Is this your model FDB1050REC2This is a brand new model and you said you just installed it!
If it is brand new!
You do not have to fix it.
You have a full years warranty, parts and labor!let them fix it no cost to you.
The first thing they will do, . You can do your self!
Go to the breaker and turn it off for 5 minutes and then on again. This should reset the system and this usually is the end to most bad starts!
try it!
Huuum
SOURCE: controls locked button on and other cycles light
Power shd be on. Press the "end of cycle" button on the right side for 3 seconds.
SOURCE: I can't get the control panel to reset. The
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
