Electrical Supplies Logo
Saud Abu-Harbesh Posted on May 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
125 DYD Onan generator Powered by Allis chalmers 11000 685T MKII Diesel Engine , need to repace the engine with newer engine. Which engin will fit to run the generator
sherlywang
Level 3:
Master:
  • Master 428 Answers
  • Posted on Dec 09, 2019
sherlywang
Master
Level 3:
Master:
Answers
428
Questions
0
Helped
198577
Points
1063
You should ask your supplier who supplied the generator to you. Because different supplier, configuration is different.
If you plan to purchase diesel generator set in future, please viist at https://starlightgenerator.en.made-in-china.com
5 Related Answers
Anonymous
  • 33 Answers
  • Posted on Apr 21, 2009
SOURCE: onan p224 engine
gonna have to go to an onan dealer or repair place.
rjivaro
  • 158 Answers
  • Posted on May 14, 2009
SOURCE: Allis chalmers b starter problem
Two things come to mind. If the plug base is too deep it could bottom out on the piston, and if the cam/shaft timing is off by a tooth or more it could also cause this problem. Check it out.
Anonymous
  • 109 Answers
  • Posted on Jun 29, 2009
SOURCE: Cub cadet 2145 (Onan engine)runs the battery down
One possible problem is the voltage regulator is out. To test this, start the engine and put a d.c. volt meter on the battery, if the voltage readout decreases as the mower runs, replace the regulator
Rick Ralston
  • Posted on Sep 06, 2009
SOURCE: allis chalmers 912 hydro belt diagram
I also have the same tractor but i have what your looking for so my email address is [email protected]
Anonymous
  • Posted on Oct 04, 2009
SOURCE: diesel fuel or hydralic oil getting into engine oil pan
In some engines have lube oil connection from the rngine block to fuel pump for fuel pump lubrication,If fuel pump oil seal damaged automatically diesel mixed with oil
2.If hydro gear pump connected with engine timing cover,oil seal for that pump once got damaged the hydralic oil goes into the engine crankcase.
Have an old allis chalmers tractor that leaks gas out of carb..is it the float or needle valve or what..
Yes it is the needle valve that is leaking or If you had this happen after a rebuild kit was installed then you have the float set to high.
How to set timing allis chalmers 670t diesel engine ?
Try one of the on-line tractor forums. Many of those guys have sources for manuals etc.
How to set engine timing on allis chalmers model 2900 engine?
SEARCH ALLIS CHALMERS 2900 ENGINE SPECS, FOR THERE ARE QUITE A FEW SITES.
If you need further help, reach me via phone at https://www.6ya.com/expert/gerardo_79638d1eac6a0a1f
Sep 05, 2014 • Garden
5helpful
1helpful
When setting points on a CA Allis Chalmers Tractor. What should the gap be and do you do it on the lobe or flat service
Set the gap on the high spot on the lob,it should be set at around 50000 or twice the plug gap,this is just a rule of thumb,but changing the timing by turning the distributer will get the engine to max performance after this has been done.
2answers
1helpful
Top Diesel Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Diesel Electrical Supply Expert? Answer questions, earn points and help others
